Question about Thermaltake AC0031 USB 3.0 Card Reader
Thermaltake AC0031 usb 3.0 operation
Hello. I purchased the Thermaltake Blacx Duet-Dual Hard Drive Docking Station and am currently attempting to clone to 2 SATAs. How do I know when the cloning is complete?
Your doing a cloning of two large drives using a USB device as I have the same docking station. Cloning a 2TB drive will take some time depending on how much data and number of files on the drive being cloned. USB even 3.0 protocol is dog slow!
Give it time and do not interrupt the clone once started.
Dennis
Apr 14, 2017 | Thermaltake Computers & Internet
I need the instructions for Thermaltake BlacX ST0005U
The manufacturer page for this item is here: http://www.thermaltakeusa.com/products-model.aspx?id=C_00002058
Their support page does not provide a manual, instructions or drivers.
I suspect that is because none are needed. This is essentially an external hard drive enclosure for SATA drives which are standard. Connected via eSATA or USB.
Oct 21, 2014 | Thermaltake Computers & Internet
Show me pictures of how the coolant looks like in 2006 pontiac g6
Replace Your Car With A KIA Sedona Because Kia Is The Best
Brand Of Car With Its 10 Year Warenty!
All Other Brands Of Cars And Trucks Are Junk!!!
Trust Me!
Oct 01, 2014 | Thermaltake Liquid Cooling System Bigwater...
My windows 7 Home will not read my new Thermaltake BlacX Duet. Downloaded new driver and still no luck. Anyone have some suggestions? Im not a programmer, but can follow instructions. Thermaltake web
try with knowingly functionating hdd, also hdd sometimes will not display in my computer due to partition error, but will display in control panel- administrative tools - computer management - disk management , new hdd-s might do the same because they only have unallocated space,and need formating. I don't know if the device itself should display itself or not, check in device manager but maybe its normal that its invisible and shows only hdd-s. If a hard disk has malfunctioned to an extent, you will not see it anywhere in windows
hope this helps
Sep 17, 2014 | Thermaltake Blacx Duet St0014u 2xhd Sata...
I have the Thermaltake BlacX 5G Dual hard drive docking station and I cannot get the hard drives to show up on my computer. I don't have USB 3 on my computer so I am using a regular USB 2.0 cable. I...
I know it might sound a bit simple, but let's start at the beginning.
Make sure that the power is properly plugged in, and that it's securely plugged into the USB port.
Put in the hard drive you will be using.
Now turn on your device by clicking on the power button.
Listen out for a "ding" or a chime in your OS.
If you DO hear one, the hard drives may need to be properly formatted or not properly assigned.
If you hear a chime, go to your desktop and right-click on "Computer" and click "Manage"
Go to "Disk Management" and at the top, there are a few options, and check for your hard drives, and right-click on the proper one and click on "Change Drive Letter and Paths" assign it a letter, and check "Computer" to see if came up.
Thanks,
Please Rate.
Jul 11, 2011 | Thermaltake Removable Storage St0019u...
How to connect the card reader to motherboard
its basically half a internal usb plug. just match it up with a different internal usb connector so you line up the right wires.
Jan 24, 2010 | Thermaltake DH 202 VJ80011N2Z Digital Home...
I need a new power on botton for the thermaltake 3 case ( the clip broke on this one and won't stay in the case hole) where can i find one so i can power on this pc...or what can i do for an alernative
contact thermaltake i even got them to send me a front panel for 15$ I really like thermaltake and stay with thier product because of the awesome customer service if they wont sell you one try Altex electronics call in and ask for a power button they wont have it listed on the website but i know they have them for sale about 3$ each but i may not be the exact one for your system but it will work
Dec 02, 2009 | Thermaltake Xaser III V2000A Extended ATX...
Thermaltake Power Express 450 problem: Have to wait one hour !
The problem is obviously with the Thermaltake PSU.
I'm thinking either it's not turning on at the same time as the primary PSU, or it isn't feeding stable, clean voltages to the graphics card. Either calls for a return to the manufacturer.
Now on to getting your video working. What you want is enough power going to your video card. Try connecting the card to your primary PSU instead of the Thermaltake one. 630W might be enough depending on how reliable the brand is, as they often lie.
If it doesn't work, getting a more powerful primary power supply will fix the problem. Go for 750W+to be safe.
Apr 11, 2009 | Thermaltake Computers & Internet
Thermaltake AC0031 USB 3.0 Card Reader Logo
88 people viewed this question
Top Thermaltake Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Thermaltake Retail Supply Expert? Answer questions, earn points and help others
