Question about Dell Dimension 2400 PC Desktop
Missing dlls when I boot up I get a avgui.exe error. When Itry to download I get a msvcr110dll error.I have downloaded and removed programs. Is there a program to reinstall dlls
    Sergeant:
  • Dell Expert
  • 504 Answers
If You use the Recovery Partition it will recover Windows for You, And it is most important to make restore points so you can recover them with that as well
Posted on Nov 26, 2013
sandrew
  • 2961 Answers
SOURCE: authorware problem
Click on site below, it might be what you are looking for. http://support.plato.com/kb/tip.asp?psid=26778
Posted on Jan 22, 2007
  • 54 Answers
SOURCE: downloaded Mail Navigator.com V1.11
Ok, Try this it should help you debug the application. First download depends.exe - this is a tool called dependancy walker it will identify all known dependecies for the application and tell you which are missing. Provide output of this info to support if you can not resolve the problem. #2 - download and install the windows debugging tools - they are located in the support folder on your OS media CD/DVD - assuming XP Pro or later. Otherwise download them from Microsoft for your specific OS. You will also need the symbols for your OS, this will allow you to probe deep into the software and provide specific infromation to the support staff your working with so they can understand why the app is freezing. -Good Luck
Posted on Sep 10, 2009
  • 76 Answers
SOURCE: I have downloaded the program, but cannot finish
Download the free program again and this time choose to save it to your desktop so you can find it easier or run it from the download location instead of saving.
Posted on Nov 10, 2009
  • 19 Answers
SOURCE: I download the ethernet controller
If you are on the internet via your ethernet card why do you need ethernet drivers?
is there any pattern of where you can and can't go on internet?
could be malware, download malwarebytes antimalware free
could be dns problems
Posted on Aug 29, 2010
  • 674 Answers
SOURCE: Changed some things on BIOS to remove McAfee virus
A slow running computer can be fixed by:
-- cleaning system junk
-- optimizing computer services
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Anyway, what are those things you have changed w.r.t BIOS? Make sure that you have removed McAfee completely through control panel.
Posted on Jun 17, 2011
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
Not a valid Win32 application
Answer:File is corrupt, bad, or missing
Download files
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Bad file
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
May 30, 2010 | Rosetta Stone Spanish (Latin American) -...
ANTIVIRUS for invalid shortcuts
I understand that you have problem that is creating shortcuts right?
Please download this utility from below link to clear virus
http://www.computerdelhi.com/
and download exe from row no. 42 on this page. you can fine many more exe tools to remove virus
Mar 11, 2010 | Computers & Internet
BOOT ERROR
it might be serious check out with the service centre ........
Jan 03, 2010 | Sony Walkman NWZ-B135 MP3 Player
Sony walkman b135 say boot error after that power
Dec 26, 2009 | Sony Walkman NWZ-B135 MP3 Player
Cannot run application (*.exe)
what is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Jul 26, 2009 | Dell Inspiron 1420 Notebook
AVG 8.5 problem encountered - avgwdsvc.exe
Reinstalling is the best option, as there are no fixes on this problem. It will take you 3 minutes.
Jul 21, 2009 | N Software AVG 2YR AVG ANTI-VIRUS V8.5 WIN...
Problem installing AVG free: error 0x800736b1
Change the name of the destination directory ( ex: C:\Program Files\Yahoo2 ) ...it works for me.
First reinstall Microsoft Visual C++ 2005 Redistributable from here:
http://www.microsoft.com/downloads/details.aspx?familyid=32bc1bee-a3f9-4c13-9c99-220b62a191ee&displaylang=en
Apr 27, 2008 | Computers & Internet
Desktop Icons
try double clicking the icon
Terry
Mar 24, 2008 | Sony VAIO VGN-N130G/W Notebook
SVC host error...
The best way to get rid of these virus is to use kaspersky anti virus,and If u still get a svc host error u have to reinstall ur operating system or do a system restore.
Download kaspersky from here
Goodluck,
Dont forget to rate me as fixya..
Jan 07, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
27 people viewed this question
Alun Cox
