Question about Philips 60P8341 60" Rear Projection Television
Model 60p8341 philips tv
My tv goes off after a couple of minutes, if i leave it off for 1 to 2 weeks then it will work for like 2-3 hrs then. a tech told me he needs to put a new SSP Board (whatever that is) and to improve the picture, he needs to clean and replace the coolant tubs. he quote me a price for $500.00, who knows something?  is the tech right? what about the price?
Your Tech is trying to rip you off - it's not the SSP Board - it's the keyboard - part # 313501707611, however, if SSP Board is some fancy tech name for it, then it's only a $15.00 part, $35.00 at the most, but they don't sell them anymore. So he must know something that we don't know....
Posted on Nov 16, 2007
SOURCE:
I have a 2002 Philips 60 in. tv with the color
2) STK392-120 ICs and 4) 6.8 ohm 1 watt metal-oxide resistors.
May 06, 2010 | Philips 60PP9202 60" Rear Projection...
Where can i find a new key bord part #313501707611 its for a phillips model # 60p8341
Try http://www.encompass.com They have the best selection of parts at the best price. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 18, 2010 | Philips 55P8241 55" Rear Projection...
Will not power on.
its either the fuse or the main filter panel ( power Board) You can get replacement boards at the following link with free tech support to help install if needed.
http://servicemanuals.vstore.ca/
Apr 02, 2009 | Philips 60P8341 60" Rear Projection...
Question about Philips 60P8341 projection tv
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
Sep 22, 2008 | Philips 60P8341 60" Rear Projection...
60" philips projection tv
HI I AM HAVEING PROBLEMS WITH THE VOLUME THERE IS NONE AND NONE OF THE BUTTONS IN FRONT OF THE T.V ARE WORKING HELP PLEASE
Mar 07, 2008 | Philips 60P8341 60" Rear Projection...
Philips model 50p8341a projection
color is off. Faces are orange sometimes, all orange, or red? Tried the remote to fix however did not work.
Nov 22, 2007 | Philips 60P8341 60" Rear Projection...
60P8341 Rear Projection - Remote does not work
Your TV needs the part 313501707611 - it's the keyboard that's the cause of your problems - but here's the catch... Philips does not make that part anymore... they say that you need to either find someone to fix the keyboard (which I've had no luck on) or buy a new Television from them... hmm, a $2000.00 TV that needs a $20.00 part now becomes a plant holder in my living room because Philips wants us to purchase a new TV from them.
Oct 06, 2007 | Philips 60P8341 60" Rear Projection...
Tv responds slowly and doesn't hold memory
HI NEED REPLACE A SSB SMALL BOARD IN LEF SIDE
IS VERY FAST TO REPLASE IS HAS ONE WHITE CABLE PLANE INSERT TO BOARD THE SMALL BOARD IS INSERT TO BIG BOARD IS COST YOU $ 319,88 LESS $ 100 CORE BACK A OLD BOARD
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Powers off by itself.
Power supply or sweep suppys have parts that are overheating and breaking down or cold solder connections. Call someone who knows this set like the local authorized magnavox/Phillips dealer/servicer. Good Luck
Aug 04, 2006 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
