Question about Siemens HF87951 800 Watts Microwave Oven
In need a siemens hf24052 microwafe Manuel - Siemens HF87951 800 Watts Microwave Oven
Door glass replacement for siemens microwave oven
I suggest calling service any work on a door needs a special detector after the repair to any door part. Only service techs carry these units.
Nov 02, 2015 | Siemens Microwave Ovens
Setting level power of microwafe samsung
You can either choose to select the SET levels for the heat which can be a direct button or you can select the power button and scroll up or down the settings. Also the weight of the food must be chosen to be effective for the heat.
Click on Microwave
Jan 31, 2013 | Microwave Ovens
I have lost my user manual for my Siemens surpresso s 40 . Where can I downloud one ?
You can download it from here.
http://www.siemens-brand.info/siemens-surpresso-s40-manual.html
Jul 20, 2011 | Microwave Ovens
I need an operating manual for Siemens HF87951 800 Watts Microwave Oven
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 12, 2011 | Siemens HF87951 800 Watts Microwave Oven
When I turn on it snaps and smells burnt
your plug wire is loose from inside microwafe tighten it.
Mar 01, 2011 | Panasonic NN-S954WF Microwave Oven
My Siemens HF87950GB inner glass panel broke during cooking, do I need to replace the whole microwave oven or just the glass or the door? where I should I go to get a replacement? Thank you!
This is a problem that at least a few others have experienced with your microwave and may be the subject of a recall although I could find nothing on their website.
I would definitely go to Siemens first as this definitely sounds like a manufacturers defect. Even if they have not publicly stated this in a recall, they likely know it is happening and may fix it (even out of warranty) if you push. ConsumerReports.org may be interested... I would talk to them if you don't get any satisfaction from Siemens.
Otherwise, the glass should be standard tempered glass that a local glass shop can get if you bring the door to them, or just a sample of the broken glass (for thickness) along with the internal dimensions of the glass.
Make sure that the metal mesh/screen remains in place and is not damaged, as this is what prevents the microwaves from escaping the cooking chamber.
Siemens Customer Support Website
Siemens Service # 1-866-447-4363
Oct 21, 2010 | Siemens HF87950GB Convection Microwave...
Glass door for a Siemens microwave hf 879
I've the same problem. Inside glass broke while heating.
May 20, 2010 | Siemens HF87950GB Convection Microwave...
Need an operation manuel for a LRMM1430SW
Click on the link below and select "Download the complete user manual"
Good Luck
LRMM1430SW Owner's Manual
Sep 06, 2009 | LG Microwave Ovens
Siemens HF87951 800 Watts Microwave Oven Logo
78 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Bill Olaschinez
Bill Olaschinez
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
