Will not spin or drain
Model number-vwsr4150boww
My lg wt-h750 wont spin or drain..
the pumps clogged or the drain pump is bad,the washer won't spin until all the water is drained out.also that model number doesn't show up,open the door to the washer look around the opening where you put the clothes in and you'll find the model number there
Nov 11, 2017 | LG Washing Machines
My washer will spin but will not drain?
Hi Vee Jayne,
Sounds like you have a problem with the drain pump.
You can google your model number/ drain pump & your local area to find a supplier/repairer.
Thanks
Damien
Nov 07, 2015 | Washing Machines
Washer stuck in drain and spin mode
Hello. I need the model number to help you accurately. When the unit drains, can you verify water *is* actually being pumped out? This is important because no washer will spin if it can't pump all the water out--modern electronic washers have to balance the load and water is an unknown, shifting quantity. I need the model number to assist you in initiating the diagnostic mode and explaining the possible error code(s) you might be getting. I hope I helped you!
Sep 15, 2015 | Kenmore Washing Machines
Kenmore he21 washer fill agitates drains but will not spin
Hello;
My name is Peter. I am a retired field service technician.
The model number you gave HE21 comes up as a Maytag hot water tank.
Open the front door of you unit. The model number should be at the top on a tag.
Repost your question with this model number.
Nov 10, 2014 | Washing Machines
Hotpoint aquarius 100 wm62
tha model number doesn't come up,you need to send the full number off of the washer,open the door and lok around the opening where you put the clothes in,you should see a tag with the model number on it,if the pump doesn't drain out the water then it can't spin until the water is drained,if it's a front load washer check the pump to see if something is in the pump stopping the impellar from spinning to drain out the water or you could have a bad pump,put the washer or drain and spin and see if it will drain.
Jun 06, 2013 | Washing Machines
The water in my washing machine does not drain once it goes to the spin cycle. How do i get the water out and what do you think the problem is?
Can you provide the exact Make, Model and Kenmore model number?
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that it does spin, the problem points to the drain pump and/or clogged hoses.
See the following on how to remove the cabinet and pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Remove the hoses carefully and drain the water into a bucket or tub.
Check the hoses and look inside the pump (try to turn it by hand) to look for obstructions.
If it won't spin or drain, the first thing to check is the Lid Switch.
See the following on how to bypass the switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Nov 02, 2009 | Kenmore 22422 Top Load Washer
The washer on my double stack won't drain or spin.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Doesn't spin
Does it drain or agitate if it drain but wont spin it is the motor coupling between the motor and transmission if it agitate but does not drain or spin it is the lid switch that tell the unit the lid is closed hope that helps Good luck
Apr 03, 2009 | Kenmore Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
