Question about Toshiba Portege 7140CT Notebook
When I turn on the power to the computer it says to press F2 to select boot device. So, I press F2 and nothing happens. So I go to setup and it reads that there is no hard drive, but the hard drive is connected. What should I do?
  • Thomas F. Schneider May 11, 2010
    Replace the defective hard drive. Reinstall everything.
  • Chris Hingee
    Chris Hingee May 11, 2010
    If the BIOS setup cannot detect the hard drive, you most likely have a faulty hard drive.
    Replace it with a new one and install Windows again to get your computer operational again.
    Problem Solver:
  • 7 Answers
Make sure the HDD is jumpered correctly. You should have a plug and play bios on that board, but you may have to enter the bios setup and go into IDE devices and tell the bios that the HDD is there, or you may need to try a different IDE cable or a different power connector. Also make sure both IDE channels are "on" in the BIOS. Other than that. When the BIOS doesn't detect a HDD it usually means the HDD is dead. More than likely it is something simple that you have just overlooked.
Please be sure to rate this solution
Posted on May 08, 2009
Toshiba lap top - satellite - when i turn it on it brings up a black screen with red writing - saying TOSHIBA and under that it says press F2 for boot selection - pressing f2 does nothing - if i hold
try pressing the F2 key during the boot process to enter set up (bios)
using the arrow keys navigate to advanced bios features press enter make sure its set to boot from your hard drive
press F10 to save to cmos restart
hope the helps
Oct 06, 2012 | Toshiba Satellite Computers & Internet
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
When I power on my Toshiba laptop is tells me to press f2 for SETUP, Press f12 for boot device selection menu. But am not sure what to do after I get on either screen
the one you press are the setup for bios settings..in the boot menu,you will select which is your priority to be your first boot,2nd and 3rd..the first boot you choice will be the one boot first..highlight the boot selection then navigate your choice..if you are going to boot it first from cd drive then select cd-rom,and if you to boot your drive which contains your system,then select hard drive as first boot..
Feb 15, 2011 | Computers & Internet
When I turn my netbook on, its say press F2 for setup and F12 for boot device selection menu but when i press either, nothing happens. (Its stuck at this menu and will not power up)
You can try checking RAM modules to see if properly seated. If are then its probably a shot motherboard. Quite common unfortunately.
Good luck
Aug 29, 2010 | Toshiba NB205-N210 Netbook
When turning computer on boot start and freeze when screen show F2 F12 . Nothing else work no matter what key I press. It wont even turn off unless we disconnect power supply and remove the battery.
It may happen due to hardware failure, BIOS mismatch or due to static charge. Let us try the basic troubleshooting. Turn Off the Computer, remove all the devices attached to
the computer, the power cable and battrey, now holdon the power button for 15 secs (make sure adpater and battery are uplugged) it will drain out all the static charge. Now,
restart the computer and keep on tapping F2, you will enter to BIOS setup utility, press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are
prompted), it will restart the computer. If still it is not booting to normal mode, then we have to perform a full system recovery & it is a distructive process as you will
loose all the datas on the computer. To do so, Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e
Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 27, 2010 | Acer Aspire One PC Notebook
I was told press F2 simultaneously on startup, nothing happened
You need not to press F2 or tab or escape unless you need to do so. If your system is ok, it'll automatically boot up, but if there's boot up problem with your system, then that's different. Thanks for using FixYa.
Jun 06, 2010 | ASUS Eee PC 1000HE Netbook
Selecting booting device
Normally with the new laptops you have to press F2 to access your bios settings, you will definitely be able to select the boot device from there.
If F2 does not work startup your laptop and watch the screen, there must be an option that will tell you which key to press to enter bios.
If the screen comes and goes to fast for you, press the pause button on your keyboard so you can read it at your own time and do your actual selection.
Hope it helps.
Aug 29, 2009 | Microsoft EF1330255 Keyboard/Mouse
My laptop freezes on the main start screen
enter to bios set up then disable the f1 and f2
May 01, 2009 | Computers & Internet
Can not Boot from OnBoard SATA Hard drive.....it keeping looping...
Turn on (or restart) your computer.
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F12>.
The Boot Device Menu appears, listing all available boot devices. Each device has a number next to it.
At the bottom of the menu, enter the number of the device that is to be used for the current boot only.
If this works and you want to change the setting permanently do the following:
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F2>.
Use the arrow keys to highlight the Boot Sequence menu option and press <Enter> to access the menu.
NOTE: Write down your current boot sequence in case you want to restore it.
Press the up- and down-arrow keys to move through the list of devices.
Press the spacebar to enable or disable a device (enabled devices have a checkmark).
Press plus (+) or minus (–) to move a selected device up or down the list.
Feb 17, 2008 | Dell Dimension 4700 PC Desktop
Install Windows XP without a CD drive
You'll need to assign the CD drive (which should show up as USB devicein BIOS or setup) as first boot device, if capable on your model/Computer. After you press power button, you should see a menu or dialog that shows something like 'press F2' or 'Delete' to enter setup. Once in setup, you should navigate thru until you find boot options or something of that nature. Select 'Boot from CD' or ' USB Device'. You should now insert your XP CD into the drive, close the tray, then choose 'Save'. It should now let you boot from the XP CD. At the first screen, you should select 'R' for repair console. It will then ask you to select an installation, type a '1' and then press the 'Enter' key. Next line will ask you to type an Administrator password. If you have one, type it, then press Enter. If no password, just tap the Enter key. Now, at the prompt, type CHKDSK C: /r as in (C: a space /r). then tap the Enter. It shoild now attempt to repair your Windows 2000 installation. When it finishes, reboot, go back into Setup and change first boot device to hard drive. Select Save and reboot LT. Have fun!
Jan 06, 2008 | Sony VAIO PCG-K25 Notebook
Toshiba Portege 7140CT Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
