My Goodman GMS81155CNA blowing cold air. Is there a pilot light? What is the usual fix. It was working fine.
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
  • 82 Answers
SOURCE: Finding Pilot light on Goodman Model caf024a2a
i think the ca # is for the cooling coil unit - the heater should start with gmXXXXX - if your unit is fairly new - the pilot light electronically when thermostat calls for heat the unit will not light if the burner door is open
Posted on Oct 24, 2009
  • 10 Answers
SOURCE: I have a Rheem Gas/Electric AC unit that provides
Heat pumps provide good heat until the tempurature drops below 35-40 degrees. After that there isn't much heat to extract from the outside air and then either the gas furnace kicks in or the electric heat strip does the job of heating the air. if you have heat strips, I would check your breakers in your panel and sometimes there are a couple of breakers right on the air handler or furnace. The ones that will be for your heat strip are 220v and will be twice as wide as your normal 110v breakers . Please don't trust a visual inspection as they can look like they are in the "on" position but are indeed tripped. Turn them all they way off and then back on. If the beakers check out you may have an open cicuit in the heat strips themselves and you will need to have a qualified HVAC tech look at your furnace to repair it.
If your furnace is a "duel fuel" and uses natural or LP gas for back up heat then your ten year old rheem probably needs a good maintenance by a qualified service tech. There is a flame sensor to clean, ignitor to check (replaces the old school pilots), burners to clean flue connections to check and much more. ALL manufacturers of any heating apliance recommend yearly maintenance. Most companies offer something for around 100 bucks. I hope this helps.
Rocco
Posted on Dec 13, 2009
Testimonial: "Rocco, this was the most thorough and helpful response I've seen from anyone so far... I tried justanswer.com and they really didn't help like this.TX"
  • 25 Answers
SOURCE: My trane XE80 will only blow cold air. The fan
It sounds like the problem is a tripped limit switch. Look in the burner compartment and on the blower assembly for a switch that looks like the one below. It will be about the same size round as a quarter. Press the red button on any of the switches you find, then re-try furnace.
Posted on Mar 23, 2010
SOURCE: Air blowing out - Pilot on but no heat.
Possibly overheating or previously overheated, these units are also prone to control box issues usually a buzzing noise at the unit it present if this is the case.
Posted on Apr 28, 2010
Working on furnace. igniter not working even after replacing.
Check flame sensor , check hoses to pressure switch not split etc
Oct 24, 2015 | Goodman Heating & Cooling
How do I fix the cooling problem on gmp125-5?
I would suggest getting a service person to check this out. If it is the compressor or refrigerant the odds are almost nil you can repair it. It could also be an electrical problem but I assume you have already checked that out.
Jul 23, 2014 | Goodman Heating & Cooling
How do I get my heater to blow hot air?
I assume this is gas . induced draft blower or ignitor.
Apr 30, 2014 | Goodman GMS90703BXA Heater
Goodman furnace, blowing cold air
Replace termorelay cose it overheating in service centre 12_26_2013_5_48_58_pm.jpg
Dec 06, 2013 | Heating & Cooling
Goodman # GMS81155CNA light blinks 4 times - furnance won't light and blower runs all the time - it's cold - please help
The 4 blinks means that the high limit switch or the regular limit switch are tripped... try to find the high limit switch... it is usually near the blower...there will be a red reset button in the center of it... push it in and the unit should work again...
if the regular limit switch is kicked you may have to replace it for the unit to work again...
This often happens after a power failure if the unit was running at the time of the failure. If you did not have a power failure, then find out why the limit switch kick out...
Here is a tip that will help you try to figure out why yourfurnace is not working.
BasicFurnace or Heating System Troubleshooting
heatman101
Apr 23, 2011 | Goodman GDS81155CNA Open Flame Mid-Size...
Our goodman furnace igniter trys to kick in, but blows cold air. Gas company came checked furnace and told me goodman igniters tend to have this problem of them working fine and then blow cold air at...
it sound slike the presure switch is not working , if it is not lighting try jumping it out it may work some times you can fool it in to working
Feb 21, 2011 | Goodman Heating & Cooling
We have a Goodman gas pack (PGB 030075-1)and no heat. A/C works fine. We can get the blower to come on but nothing but cold air comes out. Do we have a pilot light on this unit that needs to be lit?
Amy,
There is no pilot light. It is electronic ignition.
If you have a gas supply and it is turned on you have electrical problems inside the unit.
Jan 04, 2010 | Goodman Heating & Cooling
Changed the compacitor unit ran fine for half a day..then would not blow cold air..so i let it thaw overnight turned it back onit was fine..then after 5 hours..back to not blowing cold air..any...
if you let it thaw it sounds like your coil froze up
a frozen coil is usually due to lack of air flow (a dirty air filter or bad blower motor) if both of these are ok then you probably are low on refrigerant
i would suggest finding someone who specializes in goodman or someone who is certified to handle refrigerant to check your refrigerant pressures
Jul 29, 2009 | Goodman CKL24AR24 Air Conditioner
Coleman Furnace
Based on the info you have given here, I am going to make some assumptions. In "cleaning out all the components" you cleaned the air filter or changed it, cleaned the duct-work, and the intake combustion chamber? When the "furnace stays lite" the pilot and the main burner stays on? Lastly, when it "continues to blow cold air" is this when the main burner is on after long periods of time? If the answers are all yes, then maybe some of the ducts have come off, or the burners aren't working correctly.
Nov 08, 2007 | Goodman GMS90703BXA Heater
Open Questions:
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
