Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Water leaks around the steamer
When I try to use the steamer, water begins to leak from that area and doesn't stop. Is this a simple fix?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
May be. If you get the machine upside down (switched off) you will find a hole near the steam knob which allows access to a screw. Turn this screw with a flat bladed screwdriver and the knob will come off. There is a gasket (washer) near the end of this know which is the seal. I don't know where you get the seal, but try finding a rubber seal in a gasket kit. This may be the problem.
Posted on Jan 23, 2015
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
Posted on May 20, 2009
EsWorld
  • 1618 Answers
SOURCE: water leaks
try inserting the portafilter a little farther in group if it passes 90° then you will have to replace the group seal.
There is a leak and we can not find it. Any solutions
This may help?
Fill spa to highest level possible.
Heat to 100 degrees or higher.
Then, with your bare hand feel throughout the bottom rim and anywhere else you are able to: see if you can feel "Warm/Hot" water. Any "Cold" water is not the area of the leak, that water has "Travelled" there. The warmer the water, the closer you are to the origin.
Jan 01, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
I fill it up and it takes two or three days to leak out.I have tried stop leak and dye,check all the hose connect with water in a spray bottle. Is there a other test i can do.
If this is a water leak check water pump diaphram (the hole in the bottom of pump) if you see water around this area replace water pump.Also check water pump gaskets for leak.Or have it pressure tested.
Apr 22, 2011 | Chevrolet Blazer Cars & Trucks
Water is leaking from the top of my whirlpool refrigerator, what is the cause of this and how do I repair it ?
You have a icemaker? turn off its water supply, does the water stop leaking then?? Else is condensation from no frost mode which gets bad if your freeser/refrig door leaks air. shut door on sheet of paper drag paper up and down seals top and bottom if resistance is vacant in any seal area FIX IT. You can slightly REFORM a warped door be gentle! CLEAN SEAL AREAS FIRST
Nov 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Small coolant leak at front of engine hose area, not always maybe 1 out of 5 times driving to work.
If you can narrow down where the leak is coming from, it will be easier for you to fix, but it is most likely either a minor radiator leak, or your water pump. You can put a can of radiator stop leak in your vehicle, such as bars leak. It wont hurt anything. If the leak continues, and appears to be coming from the engine area, the water pump is failing, but also check around the thermostat housing, near where the upper radiator hose connects to the engine
Nov 19, 2009 | 2001 Chevrolet S-10
Leaking basement foundation
It sounds like the ground has settled around the area where the leak is, hence the traveling water. The right way to fix the problem would be to remove the porch, dig up around the basement wall, apply a sealant to the outside of the wall, install weeping tile and re-grade the soil to drain away from the house. Your best bet to begin with may be to try to re-grade the soil so it is sloping away from the house, however this is only a temporary patch, if temperatures get below freezing there is a possibility that moisture in any crack in the wall could cause further cracking and leaks.
May 25, 2009 | Hand Tools
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Leaking
You need to contact Delonghi and order a part. This is the steam/water outlet assembly. This part includes an electronic solenoid which controls the water and steam output. I have had this problem 3 times. You may find the steam/ water is very loose when you try to wobble it sideways. This is the indication as to what is the problem, (as mentioned above).
Jan 27, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
IS8100 Commercial Steamer is leaking water
Try "cleaning it" with vinegar. It could be clogged with calcium carbonate. Replace the water with a potent solution of white vinegar and water and operate the unit until the vinegar solution is used up. I use 100% of the supermarket white vinegar and avoid breathing in the "steam." Repeat the procedure once or twice with plain water. If this works, let me know.
Dec 24, 2008 | Rowenta Commercial Garment Steamer - White
Water leaking
If the water is leaking at what seems like the beginning of the spin cycle it might be the hose connection to the drain pump or the pump itself. If so, it's a lot easier to fix than the drum seal.
Dec 31, 2007 | Maytag SAV5701A Top Load Washer
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
102 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
billconfused
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
