Question about Cambridge Soundworks New Ensemble III Speaker
Ensemble foam subwoofer - Cambridge Soundworks New Ensemble III Speaker
I have a 2004 Avalon, all of the speakers (except the subwoofer) work, I noticed there is no bass and then found out the subwoofer makes no sound, does anyone know what might be the problem?
Toyota Avalon JBL Speaker Subwoofer Foam Repair 86160 ...
? 18:34
https://www.youtube.com/watch?v=vDHEbiyBt9I
Jul 16, 2012 - Uploaded by Simply Speakers
Toyota Avalon JBL Speaker Subwoofer Foam Repair 86160-AC180 .... Luckily you don't have to remove the rear deck to get at the subwoofer, ...
Removing rear subwoofer / rear deck - Toyota Nation Forum : Toy
Nov 19, 2015 | 2004 Toyota Avalon XLS
Subwoofer output distorted
Check to see if the speaker foam surrounds have disintegrated on your subwoofer. I bet it is. If so the speaker will sound like it is distorting or vibrating. Electrically it should be fine. My 2000 Avalon has this same problem with the 8" JBL subwoofer. It is a common problem and an easy fix. Go online to ebay or Amazon and purchase a speaker foam surround replacement kit (Ranges from $18.00 to $25). Youtube also has "How To" videos on how to repair this on your own. I just ordered my foam kit and awaiting the parts. Here is one for $23 but you can shop around for other deals.
Toyota JBL Speaker Foam Edge Repair Replacement Kit 86160 AC180 Avalon...
Feb 24, 2014 | 2005 Toyota Avalon
Foam has cracked on my eclipse sw9102 subwoofer, is there anyway to replace the foam?
I recommend you visit the Eclipse website to see if there is a surround kit available. Hope this helps
Aug 20, 2011 | Eclipse SW9102 Car Subwoofer
I have a 13w7 and i am wondering if its possible to find the replacement foam around the top of the speaker. mine has a tear in it and i find it hard to believe that the speaker would be wasted because of...
The foam is molded, you can not remold / repair
If it is a small tear you can repair with a bit of rubber cement. Eventuly it will fail and more will tear causing the sub to sound very bad
Sep 27, 2010 | Jl Audio 13W7 Car Subwoofer
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
One of my kicker cvrs rattle really loud at high volumes
It could be the foam edging where the speaker meets the edge of the cone. Rubber works better than foam, and I believe kicker uses foam for this model. Check for any missing screws because sometimes air leaks make that sound you hear. also try turning down the amp a little bit
Mar 07, 2010 | Kicker CVR12 Car Subwoofer
Rotten foam rubbers
You can have "The Speaker Factory" re cone them. Call for an est.first Generally gonna be less expensive to replace.
Jun 25, 2009 | MTX Road Thunder RT-1240 Car Subwoofer
Surround seperated from subwoofer
You can order repair kit here:
http://www.simplyspeakers.com/2doityourself.htm
Aug 02, 2008 | Jl Audio 12W3 Car Subwoofer
Cambridge Soundworks New Ensemble III Speaker Logo
15 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
