Question about Philips 26PF5521D 26 in. HD-Ready LCD Television
Philips 26pf5321/10 no picture but sounds fine
Hdmi and scart have sound but no picture but the tv itself has a picture
  • 2318 Answers
SOURCE: Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Dec 20, 2008
SOURCE: Philips 37PF7320A 37 in.... Problem no picture in tv and avmode
Philips 37PF7320A 37 no power but the green light is on
Posted on Jul 15, 2008
bluenadas
  • 203 Answers
SOURCE: Philips 42PFL3603 tv sound but no picture.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
Posted on Sep 27, 2009
  • 148 Answers
SOURCE: Philips 47
Hi there, they problem is not in the input to the tv (dvd/cable etc) your powerboard/videoboard is overheating! Right away place a fan as close to the back of the tv as possible, this will help cool the circuits down and might considerably prolong the usefullness of the tv..The next step in it breaking down is total powerloss, or a blinking powerlight, eitherway this is your solution;The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped (or not )please rate, thank you!d4195d7.jpg
Posted on Feb 04, 2010
  • 10 Answers
SOURCE: No picture on Philips LCD TV
One very common problem encountered on many Philips models, old and new, In some cases, the SSB board has to be replaced as the resistor on the PCB on the back of the CRT had to be fixed. In other cases the Y Sustain board had to be replaced. If the problem is not due to these two issues, then the capacitors will need to be replaced as they only have a fixed guaranteed life. Thus, it would be wise to take out an extended warranty on Philips due to this common repair issue which often occurs after the limited warranty has ended. Or you could just call your local repairman. There are lots of websites on how to fix it yourself on google. There could be many reasons. Hope this helps!
Posted on Apr 14, 2010
I have a UK satellite receiver with Roa input and scart output and want to connect it to a hdmi TV. Are there any scart to hdmi connectors and will that work or do I need a convertor as well?
Simply using a cable with a scart connection at one end and an HDMI connection at the other will not work as scart is an analogue signal and HDMI is a digital signal and so you will need to buy an HDMI to Scart Converter/Adapter to change the signal.
There no such thing as Scart to HDMI Cable HDMI Hero Splitting HDMI pictures has never been easier
Dec 22, 2014 | Televison & Video
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
Picture but no sound via hdmi
Switch your Default audio device to the High Def one. That should fix your problem.
Jan 20, 2012 | Computers & Internet
I have no picture on DVD with scart lead on AV1 and no picture or sound on separate player on HDMI connections. both players work fine on other televisions.
Is the same HDMI cable you use in other TV.Will you properly check the plug of HDMI cable at the HDMI input of your TV and check the setting.
Jul 11, 2011 | Televison & Video
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
Wharfdale DVDR24HD160 sound but no picture, i have connected vie the scart
Sound but no picture after system working fine?
Try pressing the HDMI button on the remote - if you pressed this in error and HDMI not connected the screen will go blank.
Dec 08, 2008 | Televison & Video
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
I have got wharfedale lcd 42in and a wharfdale dvdr24hd how do you set up the hdmi cable to get clear picture i have tryed taking out the scart lead out and left the hdmi cable in but i only get a picture ...
Sounds like you either have a bad card or a bad HDMI cable. Scarts are not the most dependable when it come to HD imaging there is alot of converting going on espically if the TV isnt NTSC standard to begin.
Mar 06, 2008 | Televison & Video
Problem
i have my picture going through the hdmi and the sound going through the scart. plug the scart into the back of the ps3. then the white and red wire are into my tecnics sound system and it works perfectly you just need to set it up in the sound options in your ps3. which is very easy. just select scart in the sound options. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Philips 26PF5521D 26 in. HD-Ready LCD Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
