Kyocera KM-3060 clear time for maintenance on mita km3060
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
  • 26 Answers
SOURCE: error code C0F37 on Kyocera mita KM-C1530
This code is not documented, the firmware must be reloaded and a service tech can only do it ...
Posted on Feb 21, 2009
  • 990 Answers
SOURCE: maintenance display
Hello sir; You have to change drum & developer then go to simulation U109,110,111 & U130 after that you have go to simulation U250,251 & U345 then it will clear your display.
Posted on Apr 20, 2009
n25an
  • 622 Answers
SOURCE: Kyocera mita maintenance light is on and lines
check the rectangular **** glas and table for any white out or particles... clean thoroughly... make copies... clean again... make copies... if same issue... then replace drum... but in most cases its the optics... which I advised you to clean thats causing the issue... if the issue occurs when you print an internal report then its definitely drum... if reports are clear... there is something on the glass... or on the part above it... even a little bit of black toner or ink or whiteout anywhere out there can cause a line
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 23, 2009
My photocopier km 3060 displays error code c0120.what is the problem and the solution
Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed. Poor contact in the connector terminals. Defective drum unit. Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Oct 17, 2014 | Kyocera Km 3060 Digital Copier With...
Km3060 error code 7300
Toner container problem
Toner level is not detected when toner
empty is detected.
Check the connection of connector YC5 on
the engine PWB and the continuity across
the connector terminals. Repair or replace if
necessary.
Defective toner
container sensor.
Replace the toner container sensor.
May 14, 2014 | Kyocera Mita KM 1510 Laser Printer
RESET TIME FOR MAINTENANCE ON KYOCERA KM3035
1087*2 then 251 and press start it will bring some digits then you clear
Apr 02, 2014 | Kyocera Mita KM-3035 All-In-One Laser...
Time for maintenance message
As your counter reading is above 1.5 k thats why its coming. clear it by maintenance mode by pressing 1087 1087 then go to U251 to clear it
Mar 12, 2014 | Kyocera Mita KM-1650 All-In-One Printer
How do you keep people from being able to use the maintenance key on kyocera km3060
Change the admin password on it. Or if not feasible, then put a sticky label over the button.
Nov 22, 2013 | Kyocera Km 3060 Digital Copier With...
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
Oct 05, 2009 | Kyocera Mita KYOCERA/MITA AS-M4110 Copier
Maintenance display
Apr 20, 2009 | Kyocera KM-1510 Copier
43 people viewed this question
k24674
jasbo
jasbo
