Question about Eclipse 5440
Change radioe stations - Eclipse 5440
When i change stations on my radio it changes all the settings on bass and tremble on my 2007 grand prix?
Hi Nick,
Your radio might save the bass & treble settings with each station. Try choosing a station, set the bass, treble and any other variables (mid-range, etc.) and then SAVE the station to a button. Do this for all of the buttons / stations you like.
If this doesn't solve the problem, tell us about the radio (AM/FM/Cassette/CD and Factory or aftermarket - in which case we'll need to know the make and model of the radio.
Apr 24, 2015 | Cars & Trucks
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Mar 23, 2014 | 2006 Hyundai Accent
Jeep patriot radio stations change on its own
loss of power to radio
or a bad radio.
loose fuse in radio slot?
Mar 21, 2014 | Jeep Patriot Cars & Trucks
Panasonic SC-HC271 Changing radio without remote
You can change the Radio station by using the button on the top of the stereo system. The double arrows left and right will change the radio station when in "Radio" mode.
Mar 03, 2014 | Panasonic SC-HC271 iPod Dock/CD Player...
Radio display says SAFE and will not play music
You need your radio code its 4 numbers, you use your radio preset station button to change the # press the 1 station button till you put in your code then the # 2 preset station # then 3, then fourth preset. You should find your code in your service manual. when your code is in, press the + or - button on the station search, or refer to your manual. good luck
May 12, 2009 | 2002 Volkswagen Cabrio
2001 Mitsubishi radio lost ability to change radio stations
just unplug the battery for about ten minutes to reset it. make sure you have the code for the radio if it needs one.
Feb 27, 2009 | 2001 Mitsubishi Montero Sport 4WD
Radio changes stations by itself when memory seat buttons are pushed
It is supposed to change the radio settings to what ever was programmed at the time the program was set. Your van has settings that can be programmed to personalize more than just the seat. It stores the programmed radio station the seat settings and on some vans that have the power tilt steering it changes that too. If you do not want it change the radio settings you will need to store a new setup for the number that you use with the radio station you want.
Nov 09, 2008 | 2002 Chrysler Town & Country
2000 Audi A6 Quattro Concert Radio
i'm not familar with that particular radio.... but try unhooking the battery for about ten minutes then hook the battery up again.... it should be fine.
Robert
Sep 17, 2008 | 1998 Audi A6
Static while listening to a dvd through the radio or wireless headset
have you tried changing the radio station. I had this problem and just changed the station on the radio remote and the radio itself.
Apr 27, 2008 | Myron & Davis AD-212 Car DVD Player
Car Audio & Video Logo
15 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
