Question about McCulloch Garden
McCulloch Chain Saw Mod.600133C, need to know the proportion of
Oil and gas mixture, and what spark plug to use.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
Oil, gas ratio is 40 to 1 A plug for small gas engines will work
Posted on May 09, 2009
Chain gas saw
If you are looking for the gas/oil ratio, McCulloch recommends 50/1 gas/2cycle oil mixture.
Oct 05, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
Oil,gas mixture for a McCulloch 610 chain saw
Always use good quaility two stroke oil designed for use in chainsaws ( not out board motors ) and mix at 40-1, oil quaility has moved on greatly so it is acceptable to use less oil than was once needed.
Nov 10, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Hello,I have Mac 110 model#600016c It`s in need of a little TLC The saw is about 25yrs.old and has never hadany work done on it.I need to know what the spark plug gap should be and what the gas/oil mix...
Spark plug gap should be: 0.020" and the fuel to oil ratio is 40:1. Be sure to use fresh fuel and a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Mix well in it's own container and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain saw has been sitting at dads old house . hasnt been run in 20 yrs. mcculloch (mac120). no oil in it or gas or spark plug. how should i go about getting it to run ?? i know put fuel in it . but size...
Don't think you mean electric..Anyhow when adding gas for the first time start after 20years, add a pint of oil to gallon of gas. If it turns over and starts, then you can lean it down later. Google for spark plug or go to manufacturers site. good luck
Sep 20, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Model 3516 gas chain saw runs for about 10 minutes and conks out. Wait a one day and it starts up but does the same thing. Has new spark plug cleaned air filter and proper mixture of fresh gas and 2-cycle...
The engine can be running too lean (plug will show you that, very grey and dry.) crank seals leaking (lean) blocked fuel filter in the carby and pick up hose(lean) mixture setting too lean. You can try 1st by turning the H needle in the carby anti clockwise a 1/4 of a turn and try it. only the H needle. If this does'nt do anything check the others.
Jul 02, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
Trying to determine gas-to-oil ratio on a chain saw.
Confirmation to #1: Recommended for all McCulloch chain saws at 40 to 1 ratio. 3 oz. per U.S. gal.
Jun 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
131 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
