Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Constant buzzing noise
I have been told by two techs that the packaging of the tv at sea level then shipped to our high altitude was causing the buzzing and that now new procedures are followed.  What can we do to ensure our tv doesnt go out? We purchased it here in Colorado Springs for use here.  Can a part be replaced to stop the buzzing and keep the tv under warranty?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Is the buzzing happening with the volume off?
Posted on Jan 31, 2008
SOURCE:
What do you need to do to prepare a Honda 3000i handi generator for high altitude operation
The reduced atmospheric pressure at high altitude means the standard carburettor settings will not allow sufficient fuel to flow for efficient running.
The dealer or manufacturer should be able to provide details of alternative settings - the jet sizes are usually increased a few points for every 5000 ft above sea level.
The cooler temperatures experienced at high altitude would probably change the engine oil specification to a lighter or thinner grade.
Oct 14, 2018 | Honda Electrical Supplies
Does the altitude of 4000 feet has affect on someone with low blood pressure?
I am not a doctor but I can tell you that at 4000 feet there is about 87% of the oxygen compared to sea level. High altitude is usually defined as 5000-11,000 feet. High altitude actually increases the body's blood pressure.
If you need further help, reach me via phone at https://www.6ya.com/expert/marc_162a3912222e83a4
Dec 10, 2016 | Health & Beauty
Fill out shipping details - I do not wish to send o'seas. Just straight forward in Australia
Because if its being shipped from the USA then the only option is to ship by ocean or airmail sometimes air mail is not an option most all packages are sent by ship over sea's.
Feb 01, 2015 | Computers & Internet
Sea level altitude
according to the elevation map its 25 meters or 83 feet above sea level
Mar 18, 2014 | Computers & Internet
My super tenere XTZ 750 runs pooorly at high altitude
late model EFI controlled engine ,indicates a Baro slate model EFI controlled engine ,indicates a Baro ensor problem not reporting to the ECM to adjust for less air
Take it in for a fault code check
if carbies it could be a float level problem and a air/fuel mixture adjustment or jet sizing problem
Feb 28, 2018 | Yamaha Sidewinder Twin Tech Generator...
HP increase at elevation using a Dyno Jet Dyno?
same dyno? same operator? theres something wrong. the lower altitude the better, as far as I know. But someone thats smarter than me and has high altitude /dyno experience would be better to answer the question.
Oct 01, 2009 | 1983 Mazda RX-7
When tv is on it makes a loud buzzing noise
What is the make an and model of the set?
Is the buzzing from the speakers or from inside of the set?
Is it a high pitched frequency buzz or a low pitched frequency buzz?
There are many things that can cause a buzz in a TV set. In anycase, the set will require tech service.
Jerry G.
Jul 26, 2008 | Televison & Video
Adjusting meteo function
Yes, Sir. But remember when pilots reset their altimeter with the local altitude, the pressure value matches the moment wheather pressure. It will be wrong anyway, if you reset you altitude, but the pressure readings are still wrong. Im my case it is happening. The altutide is correct but the pressure of the watch does not match the local pressure. It is 20 hpa over it. By the way, I am an airline pilot.
Mar 05, 2008 | Tissot T-Touch T33759851
Plazma TV buzzing noise
I have the same problem I can hear buzzing over the volume of the tv into the 30 range. I've had a tech out 3 times and he's coming out for a fourth. He's changed to power supplies and is bringing the 3rd next visit. From what I've read it has either to do with power supplies or grounding strips.
Jan 18, 2008 | Televison & Video
Humming noise
Most times a humming noise in a Plasma tv is associated with high altitude. If you live over 3500 ft. and when you first turn on the unit is has a slight buzz and it gets worse as it warms up then you have what is referred to as high altitude sickness. You shoul contact the manufacture with this problem and the should exchange the unit with one tested for proper operation at high altitude. If you do not live at high altitude then there is a problem in the unit that should be diagnosed.
Dec 18, 2007 | LG 50PX5D 50 in. Plasma HDTV
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
173 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
