Question about Watches
Regulating a wristwatch
My Sekonda self-winding watch is running slow. There seem to be two adjusters - a larger one with jewel in centre and a much smaller one - both seeming to point to a (+ -) scale. Do you move both levers, or what?
    Sniper:
  • 51 Answers
I would not recommend that you regulate the watch yourself. The risk of damage is too great.I would be happy to regulate it for you. This is a service that I offer my customers free of charge.you pay only the exact shipping costs.
Donald McPherson CW21
www.finewatchmaking.com
Posted on Oct 11, 2007
I've lost the instructions and can not reset it
Mate I googled the sekonda web site and this is the link-->
http://www.sekonda.co.uk/index.php?fuseaction=Static.faq
It's on the frequently asked questions page and if you click on the 10th question down (How do I use and adjust my Sekonda watch) a message drops down saying click HERE to download the sekonda instruction manual..... I hope this helps......CHEERS..
Mar 12, 2016 | Watches
What is the battery specification/type/spec for the Sekonda 3101 Men's writwatch
The practical answer is to take your watch to a jeweler who will not only open it but probably will install a replacement battery for a reasonable charge.
Mar 19, 2015 | Watches
Sekonda xpose change battery
I have an Xpose watch original 50 meters waterproof but have not worn it for a while. How do I get it going again? Does it use batteries or self winding?
May 31, 2013 | Watches
How to adjust sekonda watch strap
There is usually a small wedge pin that needs to be removed...you can tap it out by using a small nail and a small hammer or wrench....remove the links and replace the wedge pin...if all else fails a jeweler usually will do this very inexpensively...hope this helps.
Nov 04, 2012 | Watches
My automatic omega watch stops after 20-24 hours eventhough i am promised it should last for 48hours if worn continuously for 48 hours.
Almost all automatic wristwatches made today have an 18-24 hour "power reserve" when fully wound. A 24 hour reserve is actually very, very good. I can't think of a modern self-winding wristwatch that has a 48-hour power reserve because that would require a super-long or much larger mainspring than would fit in a modern watch movement / case. There may be some hand-crafted or super-premium watches that can do this, but only a very select few.
Manual wind railroad pocket watches, which were some of the finest and most accurate mechanical watch movements ever made, generally had a 40-hour power reserve. That extra capacity was created by using a large mainspring to store the extra energy. These mainsprings could be used because of the much larger size of these watches, compared to modern wristwatches.
If you are concerned about keeping your watch ticking, even when you're not wearing it, you might want to look at a "watch winder"--basically, a small watch case that rotates the watch for you, keeping the automatic winding rotor moving and the watch ticking. In addition, sitting at a computer all day will wind your watch much less than walking and otherwise moving around. Even though you're wearing your watch, if you're not moving, you're not winding it.
May 09, 2011 | Watches
How do i remove the back on my sekonda mens watch
mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
Jul 12, 2010 | Watches
Hi - took it off for 36 hrs - never had an issue - oyster submariner not moving now ... thanks for your help
This is a mechanical auto-wind watch. It self winds when worn. But if taken off for a couple of days it will have stopped and won't start running again unless it is wound.
Put it on and wear it for a few minutes. This will wind it enough to start it running again. Then set the time and wear it and you'll be fine.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 27, 2009 | Rolex Day-Date President 118238 Wristwatch
How do take off the knob that winds the hands on a wristwatch
The knob doesn't come off. It is attached to the stem, inside the watch. The only way to remove it, is to open the watch, pull the stem out, loosen the plate and move the pawl out of the way of the stem. If you ever want to use the watch again, it's best to have a jeweler or watchmaker do it.
Sep 10, 2009 | Watches
Vintage Caravelle runs fast
A quick look at ebay shows plenty of Bulova watches and only a few looking for a worthwhile price.
I think if you have it repaired for sale it probably won't be worth the effort or expense. If the watch has sentimental or nostalgia value to you I think that is what would make it worth getting a good watchmaker to look at it.
Sep 19, 2017 | Caravell Bulova Caravelle watch
Cant keep time
there is adjustment for that inside of watch or it just may need a little cleaning inside recommend take to jeweler and have serviced if you want to try cleaning at home simply take off back cover and clean with a little cigarette lighter fluid put little bit in wash around and drainout (do not soak) allow excess to evaporate out and replace battery and cover hope this helps
Sep 05, 2008 | Timex 27191 Wristwatch
Watches Logo
943 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
