Sharp mx-5141n copier paper jam
Upon warm up the machine comes up with a solid jam, when I checked the data it says POD1_FUS.. what is this
4 Suggested Answers
SOURCE: Canon 850 E001 Error
I entered service mode and it fixed itself.
With the front panel open and the copier lid/carriage lifted up, I used a paperclip and stuck it in the small hole on the center of the front grey panel (the covering of the DC controller) . I simultaneously used a pen to hold down the tab in the slot on the lower left edge that makes the copier think the lid is down...then I hit the power button. It reset the error code and all is OK now.
Posted on Apr 24, 2008
SOURCE: MX 310 paper jam
i have the same problem
Posted on Oct 21, 2008
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
What shall i do to return my sharp mx-2700n copier to operation?
have you check the sensor actuates on the registration section
Oct 19, 2015 | Sharp MX-2700N Color Copier
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
How do i fix mxm753 sharp copier pod1-n paper jam
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 05, 2014 | Office Equipment & Supplies
Sharp mx 5111n error code H5-01
H5-01 = 5 times continuous POD1 not-reach jam
reset with crop 14, then see why it is not reaching said sensor
Jul 10, 2014 | Sharp Office Equipment & Supplies
Call for service h5 01
H5 01:3 continuous POD1 not-reaching JAM detection
__Check and remedy___
  • Check JAM paper in the fusing section (Winding, etc.).
  • Check POD1 sensor harness. Check the fusing unit installation.
  • Cancel the trouble with SIM 14.
Jan 07, 2011 | Sharp AR-M450N Copier
My sharp 2300-n notified me of a paper misfeed. After clearing all misfed paper, the copier is still telling me there is a misfeed, and is not allowing me to print or copy. Suggestions?
Make sure that all of the paper jams are removed. Check every available cavity, including your paper trays. Pull each tray out and make sure there are no jams right out of the paper trays. Sometimes a piece of paper can become lodged where you cannot see it.
If you are positive there is no paper stuck in the machine, then you have a paper-path sensor that is either dirty or faulty.
Oct 29, 2010 | Sharp MX-2300N Color Copier
Error code H5-01 how to fix on a sharp arm350u
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
disconnection
Improper installation of fusing unit
Check and
remedy
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Aug 09, 2010 | Sharp AR-M350U Copier
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
H5 indication
H5-01 Five continuous detections of POD1 not-reached jam
Cancel the error with SIM 14.
Aug 30, 2008 | Sharp AR-BC260 Color Copier
Help
H5-01 indicates tha the paper sensor is defective in the fusing unit. The only way you can try to reset that one is buy turning the power off, wait 30 seconds and turn the power back on.
If the error code returns the fusing unit will have to be fixed to take care of the paper sensor.
Jul 20, 2008 | Sharp AR-M237 Digital Copier
147 people viewed this question
k24674
