Question about Pioneer DJM800 DJ Mixer (Warehouse Resealed)
Djm 800 serial number - Pioneer DJM800 DJ Mixer (Warehouse Resealed)
Pioneer DJM-800 beat effects fault
do you have the manual.
please check out the settings on turning it on echo mode.
Oct 28, 2008 | Korg Mini Kp Kaoss Pad
Power supply board
check your relay swithch, it could be shorting your connection..
Nov 05, 2013 | Pioneer DJM-800 Mixer
Voltage djm 400
You do not need to replace anything, buy or have a stepdown transformer
of at least 200 watts rating.
Step-down transformer specs:
220V input
110V output
However , there are other DJM400 versions that have a built in 220V
input. Have a tech to guide you.
Oct 22, 2012 | Pioneer DJm 400 Professional DJ Mixer
Tap and fx buttons are stuck hi my name is john haill i am blind and own a djm 800 i my mum was cleaning my gear and she used polish and now there stuck
Use some CRC226 around them to break the polish residue and lube them. It should only take a little. CRC226 is available at Home Depot in the electrical dept. It is plastic safe.
Jun 03, 2011 | Pioneer DJM800 DJ Mixer (Warehouse...
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Since it works with your other mixer, the DJM400 is probably fine. You have a ground loop.
Make sure ALL, and I do mean ALL... (re-read that if there is any confusion) interconnected equipment WILL BE powered from the same receptacle or source. If speakers or amps are powered from one place and the DJM is from the other end of the room you likely have a ground loop and you can ex[ect buzzing. Run extension cords alongside the audio leads if necessaryy to carry power from where the amps or speakers are plugged in back to the DJM400 and ANY pther connected equipment.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
Just bought DJM 800 mixer and the screen went out within 5 mins. The display stayed off and never came back. any ideas
This is likely a power supply problem. If under warranty have it repaired right away. Unless you have electronic repair skills, this is not a DIY project.
Download service manual here:
http://elektrotanya.com/pioneer_djm-800.pdf/download.html
Dec 22, 2010 | Pioneer DJM800 DJ Mixer (Warehouse...
My DJM 400 power button does not stay on, when I hold in the power button it does have power, but does not switch to stay on. Any quick fixes for this? Thank you.
The only "fix" for this is to replace the power switch. The internal latch has broken. I have seen this a few times. You can get the part from Pioneer directly. Contact them and request the power switch for your specific model. They may also request the serial number as there were a few variants of this model.
Dan
Jun 14, 2010 | Pioneer DJm 400 Professional DJ Mixer
One Output low on DJM 400
This may not be the correct solution, but have you checked the switches on the back of the DJM-400 to see if one output is set to "PHONO" mode?
Apr 17, 2009 | Pioneer DJm 400 Professional DJ Mixer
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Pioneer DJM800 DJ Mixer (Warehouse Resealed) Logo
23 people viewed this question
Top Pioneer Music Experts
Vito Vacirca Jr.
Are you a Pioneer Music Expert? Answer questions, earn points and help others
