Question about Insignia Televison & Video
Costomer support i bought a 39" Insignia flat screen television on August 2, 2013. when i turn the television on the screen comes up as usual but within a minute the screen goes dark but the sound stays on. If i turn the television off and turn it back on, usually the screen stays on. it has now begun to do it more frequently and it takes turning it off and back on four or five times now before the screen stays on.
    Problem Solver:
  • 9 Answers
Sounds like a projection issue within the TV itself. Nothing that I think you can fix. A year is not up and it should be under warranty. Send it back to them and they will send you another or fix it. I had an issue like this a while back and I left the TV off a couple of days under a window with direct sunlight. I think it was too Humid in the room it was in or moisture set in. Either way, It was not under warranty and the picture returned like it was brand new. My mom has it now.
Posted on Nov 26, 2013
Coldcut
  • 1554 Answers
SOURCE: Picture clarity
Sounds heat circuit related, and if under warranty you should notify them before you have to pay for the tuner or sync board.
Posted on Feb 04, 2008
  • 55 Answers
SOURCE: Screen goes dark
Man, there are a ton of people on here that are having problems with Polaroid LCDs. If your TV is that new, it is definitely going to be covered under warranty and I would call them and tell them what exactly is going on with the TV. Their Customer Service Hotline number is 1-800-605-5364. It's ridiculous that the TV is only a couple months old and already the picture is going out. You would think after spending all that money you would have a TV that would work great for years!! Hope this helps...
Posted on Sep 08, 2008
SOURCE: Insignia 32" TV turns off after turning on and red light comes on
Hi
I have Philips 42pf9431d/37b and i re hucked up my tv.
It truns on and goes to green and red how can i solve it.
Posted on Apr 12, 2009
  • 36 Answers
SOURCE: TV TURNS ON HUMMING SOUND FOR ABOUT FIVE MINUTES AND GOES AWAY
go in audio section and select mono instead of stereo or sap
Posted on Sep 18, 2009
  • 10 Answers
SOURCE: When turning on the television it does not turn on
You have a defective power supply, most likely faulty electrolytic capacitors on the power supply board. The board can be repaired, I fixed one for a friend, it took 2 new capacitors $0.90 each.
Posted on Dec 17, 2009
Insignia 32 flat screen will not stay on. Power on and go right back out? What is the cause for this to happen?
Top 144 Complaints and Reviews about Insignia TV
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.5 - ‎80 votes My son purchased a 42" Insignia TV for me before he died. ... Bought 50 inch Insigniaand after 13 months screen starts going black but sound stays on. ... I was having problems with the Netflix app on my 42" Insignia smart TV, so I took the ...
Sep 23, 2015 | Insignia Televison & Video
I need the stand for a 32" insignia flat screen
You can buy an assortment of universal support bracket or universal stands at stores like walmart, Best Buy etc.... Check the back of your insignia and you will see the threaded holes made for this kind of bracket. I bought a 42 inch flat screen and bought a combination table/mounting bracket. It's great. Make sure you get a bracket that matches or exceeds the weight of the TV though. Good luck and feed back if u can.
Apr 18, 2013 | Insignia IS-LCDTV32 32 in. Television
50" Insignia plasma made a pop sound
This might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
I can't get reid of the Insignia HDTV 2XHDMI logo bar to stop coming on like a screen saver..please help
Go into your menu with your remote control. There should be a way to get rid of it.
Apr 04, 2012 | Insignia Televison & Video
My 42" flat screen phillips
I'd post TV model number first - it's on the back of the TV -and I'd also post a picture if I could.
The lines on the screen do not usually go with the "channel not available" problem and the likelyhood of you having both at the same time is , well, small.
Sep 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
26" Insignia TV, screen is
Go to your menu and choose picture. See if your settings are normal or if the brightness is turned down. If it isn't then it's a problem with the T.V.
May 04, 2011 | Insignia LCDTV26 26 in. Television
Why no color
just try to look the menu and set up the color. if no your tv has a defect.just consult to the costomer service support.
Jun 25, 2010 | Insignia NS-L322Q-10A LCD TV
My insignia tv - there is power - no screen - no
I hope you bought a service contract, definitely an electronic problem and you're going to have to have it fixed by a technician
Dec 08, 2009 | Insignia LCDTV26 26 in. Television
26'' Insignia Startup Screen
This problem requires a service technician to check out you television for component failures on the power supply board and the main board. You have a failure in either drive voltage to power you video processor or a break down in the signal transferring components.It could be as simple as cold solder joints or a failure of capacitors in the signal processing circuits. They have a self healing components and will restore temporary operation for short periods of time.You could also have a failing video processor chip and chips that are being damaged everytime you turn your unit on.. These problems usually occurs from over heating going on inside you television. You need to get it checked out before it get worse.Here is the number for Insignia Customer service: 1-877-467-4289. Hope this helps you with your problem.
Mar 12, 2009 | Insignia LCDTV26 26 in. Television
INSIGNIA TV SCREEN - BLANK ???
the pwr supply is not regulating properly what happens when turned on regulation starts to swing and ripple increases causing lines in image panel....john
May 27, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
35 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
