Question about Eastern Tools & Equipment ETQ IN1800I 1,800 Watt 3.4 HP 4-Stroke OHV Portable Digital Inverter
Need a NGK spark plug for a ETQ IN1800I - Eastern Tools & Equipment ETQ IN1800I 1,800 Watt 3.4 HP 4-Stroke OHV Portable Digital Inverter
I have a polaris ranger 6x6 500cc the plug in it now is a ngk bkr5e 7938. a friend gave me 2 unused ngk b7e s plugs and said that they wood run fine. Are these 2 ngk b7e s ok or what?
The figure 7 represents the heat range of the plug. Usually it is unwise to deviate from specifications unless problems force choosing a different heat range. If the spark plug regularly fouls then a hotter spark plug could improve the problem - with NGK that would mean moving from 5 to 4.
Any move must be made with care to avoid the engine damage possible if the spark plug is too hot.
Hot and cold plugs, incidentally, indicate the amount of heat the spark plug dissipates from the centre to the body and doesn't affect the temperature of the engine. Broadly cool running engines need hot spark plugs and hot running engines need cold plugs so in each case the spark plug nose will achieve the self-cleaning temperature without becoming too heated.
Moving from a 5 heat range to a 7 (NGK) is moving to a colder plug so yes it will run fine, at least for a while, though you could find plug fouling might be a problem...
Jun 18, 2017 | ATVs
Further to my question about a weak spark on my etq 1200 ,would one of these be the problem, magneto,igniter ir capacitor?
A lot small ignition spark appears to be weak when they are not.
A couple things to check. make sure your spark arrestor is clean and your ignition timing is correct; otherwords, that the flywheel key is not sheared.
Nov 25, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
Can,t get carb off to clean ETQIN1800i
There are two plastic nipples that are pressed into rubber grommets, just grab the bottom and pull straight out while wiggling the air box assembly. Make sure you pull the rubber fuel lines out of the way so that the air box cam come straight out. The resistance you are feeling is either the rubber grommets or the fuel lines in the way. I have had mine apart a dozen times!
Dec 28, 2013 | Eastern Tools & Equipment ETQ IN1800I...
Owners manual
no, you just have to dig into it further to find your issue. sorry but these generators I don't see very often. Like I've worked on 5 in the last 6 years yet they aren't all the same
Etq in1800i will not start
Did you just clean the Bowl in the Carburetor or did you make sure the tiny holes in the Jet was clean too? Not familiar with this model but I doubt it is anything more than Gravity fed.
Dec 01, 2013 | Eastern Tools & Equipment ETQ IN1800I...
Need Owners Manual for an ETQ 1800 w inverter/Generator
Northern tools has it here, even though it's a discontinued product:
http://www.northerntool.com/images/downloads/manuals/166520.pdf
Apr 11, 2013 | ETQ IN1800i Generator Digital Inverter...
Gas in crankcase while running
Probable cause would be a carburetor that is over-filling, Possibly from a sticking float, or an over-pressurized fuel tank.
Make sure that the vent on your fuel tank is working properly, and remove the bowl from the carburetor to make sure that the float moves up and down freely.
Mar 08, 2013 | ETQ IN1800i Generator Digital Inverter...
I need the synonym spark plug of NGK TR11
should have MOTORCRAFT plugs, but you can use NGK. ck out the NGK website.
http://www.ngk.com/results_app.asp?AAIA=1119642
Oct 01, 2009 | 1995 Ford Explorer
Eastern Tools & Equipment ETQ IN1800I 1,800 Watt 3.4 HP 4-Stroke OHV Portable Digital Inverter Logo
49 people viewed this question
Top Eastern Tools & Equipment Electrical Supplies Experts
Bernie Knutson
Bernie Knutson
Level 1 Expert
jhnolson
wadingriver
wadingriver
Are you an Eastern Tools & Equipment Electrical Supply Expert? Answer questions, earn points and help others
