Question about Konica Minolta Office Equipment & Supplies
Change tray 1 plain univ
Printer not printing
Soulvisitor
  • 1113 Answers
SOURCE: tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Posted on Dec 18, 2007
Kevin Hayes
  • 167 Answers
SOURCE: Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
Posted on Jun 06, 2008
SOURCE: Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Posted on Jul 11, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: How do I change tray settings from tray 1 to tray 2?
Browse through the menu's of the printer
Paper Handling Menu, Set
Tray 1: Any size / Any Type.
Tray 2: A4 Size / Plain Type.
This should solve the issue
Regards,
Nikhil
Posted on Sep 09, 2009
  • 628 Answers
SOURCE: printer will only print from tray 1 and not tray 2
In your printer properties page you can change the default tray.
Posted on Nov 27, 2009
How do I change the default on my HP P30005dn to Tray 2?
Normal default on HP is tray 2, however if you do not have that tray set for plain paper letter size the printer will default to whichever tray has letter plain paper installed. You should also check your print driver default settings to ensure that tray 2 is set as default tray.
Aug 14, 2014 | HP LaserJet P3005dn Printer
Printer selects tray1 as default tray. how can this be changed?
Tray 1 by default is set to any size, any type, which means that no matter what you print, it will pull from tray 1. You can change that by setting tray 1 for a specific size and type, such as 8.5" x 11"(Letter) and Plain paper, and then going into the print driver options (Control Panel, Printers & Faxes, right click on the HP 3550 and select Properties) and under the paper input tray, change it to either tray 2 or 3.
Jun 09, 2010 | HP Color Laserjet 3550 Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Regards,
Nikhil
Jul 10, 2009 | HP LaserJet 2420 Printer
Printer message apears "change tray 1 plain letter" when i press print. will not print until i press select. Ive tried changing printer setting and cant seem to fix it..
change the paper type at the printer to plain letter, or in printer properties from the start menu.
-Carl, please let me know if this helps.
Jun 25, 2009 | Office Equipment & Supplies
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
WON'T PRINT
There is a Paper Menu option somewhere in the menus on the op-panel. You need to go to the Paper Type option and change the Paper Type for Tray 1 to plain paper. You can also hit the Select button when you get this message and you will print.
Feb 19, 2009 | Lexmark T644 Laser Printer
Somebody has messed with the settings and now whenever we print we have to press "Select" for each page
The tray 1 is same as manual tray, it opens in front of you.
normally (in windows) you need to configure printer driver from printers => properties => printing preferences.
Oct 14, 2008 | Lexmark T632 Laser Printer
Won't switch back and forth between letter and legal paper
go to printer properties & change the default tray
Jun 26, 2008 | Lexmark T632 Laser Printer
Tray 1- load plain letter
Linda,
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
