Question about Video Cameras
Sony ccd fx500e playback problems
Cassette holder does not close
techman
  • 3130 Answers
SOURCE: "reinsert the cassettee" error in Sony HandyCam CCD-TRV 438E.
The camcorder most likely is not detecting the tape, you have a bad sensor and these sensors all come on a flex type board and the flex board is mounted on the chassis surface. This will mean that the entire mechanism will meed to be diassembled, and is a very big and costly job. My opinion is that this repair will run you abut 250 to 300 bucks and this camcorder is not worth this as new camcorders are under 200 bucks. Good Luck
Posted on Apr 03, 2007
SOURCE: camcorder cassette holder stuck/won't eject
Try taking the battery out...
Posted on Jun 30, 2008
AlmostBob
  • 550 Answers
SOURCE: problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Posted on Oct 23, 2008
SOURCE: I have a Sony Handycam Video 8 ccd-TR330E PAL.
how to transfer video to computer, any cable ? raymonddcrus@yahoo.com
Posted on Aug 31, 2010
SOURCE: I have a Sony Handy CAM 8 CCD-FX310. It will
I had the same problem with a Sony FX410, not much different than a FX310. With my camera all i had to do was to push the top down with a gentle push, it would engage and play and record normal. Don't force it hard, just a light pressure to help the cradle down. Most of these Sony cameras are crappy when it comes to loading the tape, most if not all the Sony's i've had end up with this problem, no matter what model you have. I've taken my camera competely apart and could not find the problem for not pulling down the tape, don't know if it can be a sensor or what, i never could find anything broken or loose or misalign, i oiled all the joints and moving parts with a light dab of thin oil, it worked fine except for that darn cradle not pulling down the tape.
Another thing that causes this is when the tape is to tight? In other words the tape should have a slight **** in it, i once ran into this big problem when the tape would not load and the camera kept ejecting it over and over. It was when i tried a new tape that i noticed how well it loaded yet the other tape wouldn't load. So i pulled out the tape and poked that little hole on the back right below the left hand pick up reel, i then turned the reel with my finger and gave it some slack, not much just enough to see the tape a little loose. I then reloaded the tape and it worked like a charm, seems that if the tape if to tight the camera won't accept it as the reels need to adjust back and forth for a few seconds, its that wacky sound you hear when you load a tape, seems like it has to adjust the tention inside the take up reels. Hope this might help you some?
Posted on Nov 30, 2010
Testimonial: "Seemed to work for a bt"
Sony handycam ccd-tr9 video playback is distorted
sir,
the video head problem, try to clean it with head cleaner cassette. play the cleaner cassette several times, test, if still problem must change the video head.
Jan 20, 2016 | Sony Video Cameras
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
Feb 23, 2010 | Sony Video Cameras
Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Dec 04, 2009 | Sony Handycam CCD-TR64 Camcorder
Cassette holder mechanism wont close all the way. Will go part the way down and then come back up and eject
Look carefully inside for something jamming the carriage. If everything is clean and free there is a sensor not registering.
Eric
Jun 24, 2009 | Sony Handycam CCD-TRV107E Camcorder
Problem with SONY DCR-HC90E
Reinsert cassette message comes when mechanism doesnt load cassette properly. If this error message comes again n again, means mechanism has some problem and unable to do task.
Aug 07, 2008 | Cameras
Won't playback
Use good quality video head cleaning cassette because video head seems dirty/ clogged. If it doesnt solve the problem, video head need to be replaced.
Jun 25, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Playback problem
Video Head is dirty/ clogged. Use good quality Video Head Cleaning Cassette.
Jun 08, 2008 | Sony Handycam CCD-TR517 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Can not load any cassette even empty cassette holder can not be closed.
I had the same problem and solved it by removing the battery to allow the camera to reset. Worked fine after that.
Sep 24, 2006 | Sony Handycam CCD-TRV11 8mm Analog...
Video Cameras Logo
71 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
