Question about Sony MDR-RF945R Headset
Battery replacement for Sony mdr-rf945r
What battery type is needed for this headset?
5 Suggested Answers
SOURCE: i accidentally cut the wire on my sony mdr-D777 headset. how do i repair?
If you matched all the wire up in their original configuration then there is not much else to be done.you could try taping them individually so that none of the wires are touching. At this point I would invest in a new one, Perhaps blueooth ; )
Posted on May 27, 2008
SOURCE: Where can I find replacement battery BP-HP550???
SONY website does not have this battery in search results. Is there any other equivalent?
Posted on Feb 04, 2010
  • 6 Answers
SOURCE: i need rechargeaable
Since many Sony headsets use the BP-HP550-11 battery pack, I assume your battery pack is the same. If not, I assume whatever battery pack your headset came with, it is some type of plastic holder that holds two batteries together. Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
Posted on Dec 01, 2010
  • 6 Answers
SOURCE: I have searched the web
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work (be able to be charged using the cradle) in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
I need replacement batteies for my sony headphones and can not find them
My headphones (after several years) got to where they would go dead in about 1/2 hour. I used Panasonic AAA H8 Ni-MH 630 mAh. They last longer and get much louder than the stock batteries. I was able to remove the old batteries without breaking the holder. They work better than new.
Jul 15, 2011 | Sony MDR-RF960RK Consumer Headset
Jak mam wymienic baterie w sluchawkach sony mdr -rf 800r jak odkrecic ,??
Feb 10, 2011 | Sony MDR-RF960RK Consumer Headset
It appears that my battery for these headphones doesn't hold it's charge....It's hardly been used Battery type.....BP HP550-11 for headphones Serial No MDR RF 840RK
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece on the BP-HP550-11 battery pack (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
Dec 03, 2010 | Sony MDR-RF960RK Consumer Headset
I need rechargeaable battery for wireless sony stereo headphones mdr-rf860r
Nov 19, 2010 | Sony MDR-RF960RK Consumer Headset
I have Model MDR-RF970R and the battery is not holding a charge. Where can I get another battery? The # on the battery is BP-HP550-11/2.4v 550mAh. Thanks. Joe
Sony has some special case they put around the original 2 batteries to hold them together.
You don't need to buy special batteries. You can put regular AAA NiMH in.
To remove the compartment cover on the headsets make sure you hold down the pressure button on the left headphone to release the cover. Mine has the words "PUSH" on them.
With the cover removed you can then see the original BP-HP550 sony battery. Which you can remove and put 2 regular AAA batteries in.
Oct 07, 2010 | Sony MDR-RF960RK Consumer Headset
I have searched the web for this battery BP-HP550-11/2.4V (two batteries), to replace the ones in our Sony wireless stereo headphone system model MDR-RF970RK.
Sep 22, 2010 | Sony MDR-RF960RK Consumer Headset
Need replacement batteries for Headphones(Sony) MDR-RF970
You can use 2 AAA batteries. I just tried it on some similar headphones (MDR-RF970R).
Aug 26, 2010 | Sony MDR-RF960RK Consumer Headset
I need rechargeable bp-hp 550 batteries for my Sony wireless headset. Where can I get them?
http://www.fixya.com/support/t1655049-find_replacement_battery_bp_hp550
earlier post i found.
Aug 07, 2010 | Sony MDR-RF960RK Consumer Headset
Lost my manual. how do i get the battery out?
Click Sony Support to download instruction manual copy of MDR-RF960RK and check page- 4 for battery replacement.
Thanks.
Aug 18, 2009 | Sony MDR-RF960RK Consumer Headset
Radio Communications Logo
Top Sony Radio Communications Experts
 Grubhead
Grubhead
basssplayer
Level 1 Expert
Piyal Perera
Piyal Perera
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
