Question about Polar Cadence Sensor W.I.N.D
Cannot get my new cadence(WIND)sensor to work. will aparently teach. Any ideas
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
No reactions to any buttons:
Reset the training computer by pressing all the buttons simultaneously for two seconds until the display fills with digits. Press any button and set the time and date in Basic Settings after the reset. All other settings are saved. Skip the rest of the settings by pressing and holding STOP.
Polar Cadence Sensor W.I.N.D.
To activate the cadence sensor in your training computer, select Settings > Features > Shoes/bikes > Bike
1/2/3 > On > Cadence > On.
Teach new sensor? is displayed.
• If your sensor is already taught, select No.
• To teach a new sensor, make sure that there are no other cadence sensors nearby (40 m/131 ft) and then select Yes.
After selecting Yes, Start test drive is displayed. Rotate the crank a few times to activate the sensor.
The flashing red light indicates that the sensor is activated. Completed is displayed after the
teaching has been finished. The training computer is now ready to receive cadence data.
To return to time mode, press and hold the STOP button.
Good Luck,
Techjoel
Posted on May 23, 2009
Vdo m5 bike computer has no speed reading . Cadence reading is fine. I replaced all new batteries. Just can't make it work, sometime display shows transport . Don't know what is that meaning ?
The computer goes into Transport Mode when it detects the bike is moving without the wheel moving (as on a car carrier) so that means the wheel sensor is not working. If you take a magnet and pass it right by the sensor several times and get no cadence count then the wire is broken or the cadence portion of the computer is non-functional. Unless it's the wire and you can fix it you need to buy a new computer.
Aug 18, 2017 | Cadence Cycling
I have an older cat eye computer. Wires. The cadence function stopped working. All other functions are good. I installed a fresh battery, I adjusted the sensor location. Still does not count cadience
Aug 16, 2017 | Cat Eye Cycling
Sigma wireless bicycle computer. Model BC 1606L. Wireless cadence monitor has abruptly stopped working. All other functions of this unit working perfectly. Transmitting unit and receiver have new...
Did you throw the magnet on the crankarm? If not check the alignment of the transmitter and the magnet - sometimes they need to be quite close. Sometimes they just fail. I have seen instances where cadence worked and speed didn't and vice versa - so the unit is transmitting perfectly, but one of the sensors has gone bad.
Jun 12, 2011 | Sigma Sport BC1606L Dts Wireless Bike...
I have a cateye strada cadence computer. The wheel sensor is working fine but the cadence sensor isnt detecting anything. The manual says that the magnet must be within 3mm of the sensor but, with the...
I have the same exact issue - all works but not the cadence sensor. I am going to try using some rubber shims or something...wish I had an old innertube to use.
Jan 26, 2010 | Cadence Cat Eye Strada Computer
Battery replacement polar cadence sensor CS 200
Polar sucks, I'm going to Cateye
Sep 06, 2009 | Polar CS200
Cadence does not register on edge 705
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Jul 14, 2009 | Garmin EDGE 705
Garmin Edge 305/GSC10 Cadence and speed sensor
Had the same problem. Here is how I fixed it.
1. Changed the battery in the cadence sensor. (GSC10)
2. Turned on my garmin 305 edge outside to acquire satellites (probably not nec but did it anyway)
3. Pressed reset on the GSC10, saw red/green flash (what order?)
4. Here's the missing step: On the Edge unit, go to SYSTEM.
5. Scroll to bottom, choose ACCESSORIES.
6. On acc. page, go to bottom, under Cadence Sensor, to the option RESTART SCAN. Press That. Now your cadence and speed should work.
Feb 23, 2008 | Garmin Edge 305 GPS Receiver
Polar Cadence Sensor W.I.N.D Logo
378 people viewed this question
Top Polar Cycling Experts
kirkjw
Level 1 Expert
mcgsp
Level 1 Expert
Ngoro
Ngoro
Are you a Polar Cycling Expert? Answer questions, earn points and help others
