Question about Vacuums
Sony transformer E239177 output polarity - Vacuums
3 Suggested Answers
SOURCE: Sony transformer E239177 is the
I have the same problem... Did you find the solution? Thanks in advance.
Posted on May 01, 2011
I have a same problem too,, but now i finally solve it LOL. It 10vvvvvvvv. ^W^.
Posted on Jun 09, 2011
Rainbow Series E - we replced the plug with a non polarized plug. the breakers in the house popped off. no burned motor smell
So now you have to check the wires. The reason there is a polarized plug is to prevent the hot wire from being sent to ground. Obviously when you changed the plug, the hot wire was sent to ground. The current draw then burned a wire in half. There is no fuse.
Apr 11, 2015 | Vacuums
My problem is that Model 16N5-K, 120v 60Hz 12 amp Bissell Vacuum cleaner has no wattage indication in the unit itself, in the box, in the product brochure. our power output in the Philippines is 220v. I...
All the information you need is in your text :>)
Volts, Amp Watts To determine the wattage, use a simple multiplication formula. The ampere (or amps) is the amount of electricity used. Voltage measures the force or pressure of the electricity. The number of watts is equal to amps multiplied by volts.
How to Calculate Wattage (Formula and Tools) - wikiHow
www.wikihow.com/Calculate-Wattage
To find a step down transformer for 1440 watts, you will buy a new vacuum cleaner cheaper.
volts amps watts equation Google Search
Oct 01, 2017 | Vacuums
I have a Ferguson step down transformer that takes input as 240V and outputs 115v The model is : TS 115/2000EC I need the wiring diagram for the output side
If it is 240 to 120/115, there should be two high side wires and two low side wires and ground wires, isn't that true?
Please post back, thanks.
Gary
Mar 20, 2011 | Vacuums
My silent ionic breeze GP just stopped working (no blue light, no static). only a couple of years old. cleaned weekly. how do I obtain someone to possibly fix it as trouble finding replacement?
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKWj6N--u6cCFYjsKgodLxrBBQ
Airpurifierrepair will fix your unit but it starts at 159.00 flate fee.
Here are some other things to try first:
Dirty Collection Grid.
  • In case of a problem with your Ionic Breeze air purifier, the first thing you should do is clean the collection grid. According to the Ionic Air Breeze instruction manual, the most common problem with the units is that the collection grid gets too dirty and the unit no longer effectively cleans the air. Removing the collection grid from the top of the unit, then wiping it down with a damp sponge or rag, as well as turning the entire unit upside down several times to dump out any dirt from inside the housing, will help restore the unit to maximum operating efficiency.
Glowing Blue
  • Another common problem with the Ionic Breeze unit is that it no longer glows blue, which it is supposed to do when operating in germicidal protection mode. If the unit is no longer glowing, it is likely that the UV fluorescent bulb inside the unit has died or has decreased in output. The bulbs are meant to last for about a year, and touching the bulbs or getting them in contact with oil or dirt will shorten their lifespan. Try replacing the light bulb before assuming there is a more serious problem with your Ionic Breeze air freshening unit.
Transformer or Circuitry Issues
  • Other problems that may occur with the Ionic Breeze that you will need to troubleshoot and repair include transformer or circuitry problems. If the transformer goes bad, the unit will not work at all, and will have no power when you attempt to turn it on. Similar problems can occur if the circuit board is defective. Because of the danger of electrical shock or damage, it is best if you have a repair facility work on your Ionic Breeze unit if you suspect transformer or circuitry problems
Mar 06, 2011 | Vacuums
I have a musical maisto carousel but have lost the AC adapteR can you advise what type of adapter I need.
It it looks like this one:
Maisto
Model# DPX412012
INPUT 120V AC 60HZ 9.8W
OUTPUT 6V DC 800MA
CLASS 2 TRANSFORMER
A wonderful person on EBay, seashells-resale-by-the-seashore, gave me this information for my husband's carousel. It had been a gift to his mother who passed away. Now we can get it working for the grand & great-grand children.
Nov 09, 2010 | Vacuums
Replacement power supply is impossible to find... Even techworld the original manufacturer does not have it listed.
If you look at the original power supply, there should be a label with the following details included:
Output voltage
Maximum output current
The polarity of the output connector (which bit is positive and which negative).
If you take this info to an electronics retailer, e.g. Maplins in the UK or Radio Shack in the US, they should be able to sell you a universal power supply that can be configured to match.
Nov 04, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
What is the wattage onroomba 560
The power supply isn't a transformer, its a switching power supply. The power supply is different for different locations, but you should not plug a 110V only power supply into a 220v source or vice-versa. You should contact iRobot if you wish to obtain the correct power supply for another location or to determine if they have an autosensing model that can sense and adapt to either 110v or 220v. You can also use a step down transformer to convert from 220v to 110v. The charger should be using 20W or less, but it will be pulling the current in narrow surges from the peaks of the voltage wave (aka a high 3rd harmomic current) and you will need to use a 40W or larger transformer to avoid unexpectedly overheating the transformer core.
Aug 25, 2009 | iRobot Roomba 560 Robotic Vacuum
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
