Question about Dell Latitude E6400 Notebook
E6400 batery cable error 2000-0411 - Dell Latitude E6400 Notebook
How do i hook my laptop up to my samsung flat screen tv
You can go 2 different ways either through VGA along with a good old fashioned mini audio cable or run a single HDMI cable, I recommend the HDMI for a better HD experience and a single cable that covers both audio and Video for the Dell Latitude E6400 Notebook you will need a Display port to HDMI adapter but its well worth the experience.
Dec 27, 2013 | Dell Latitude E6400 Notebook
How can I hook my dell latitude e6400 lap top up to old sony Trinitron with one vga cable connected to laptop has rca and s-video also on same cable only one side thoe
If I understand your configuration correctly, you have a VGA cable that plugs into your laptop and you want the other end to connect to your TV? They make a VGA to S-video converter box that you can buy to make the connection http://www.bestbuy.com/site/agptek-vga-rca-s-video-to-vga-converter-box-adapter-switch-for-pc-lcd-monitor/1308798590.p?id=mp1308798590&skuId=1308798590
Sep 23, 2013 | Dell Latitude E6400 Notebook
Led backlight dell e6400
if you are sure the LCD is off, is symptom the you must replace.
You can run the utility for diagnostic, you can connect another monitor? and test. Otherwise you need to replace it by yourself, or go to the repair shop computer.
God bless you
Jul 30, 2013 | Dell Latitude E6400 Laptop
I have a Latitude E6400. I have tried to use the wireless connection but it wouldn't connect. I have to connect to the internet via an ethrenet cable only. It restricts my movement & makes me handicap.
make sure the wireless switch is on then try to update the wireless driver of your computer. you can download the latest wireless driver from your computer manufacturer's web site then restart the computer
Jun 11, 2010 | Dell Latitude E6400 Notebook
I've just bought Cable to connect with VGA port of DELL E6400 connect to AV TV but I cannot switch to TV. I'm not sure whether I need to set up resolution at my notebook or not.
Did you press Fn+F8? You should also try right clicking on the desktop, bringing up display properties, and messing around there. Alternatively, there may be a setting on your TV that is not set properly.
Apr 17, 2010 | Dell Latitude E6400 Notebook
Dell E6400 dvd drive will play dvds but will not burn them
it may be writting software problem, please reinstall it. if no go then it is optical drive problem, run the diagnostic by pressing f12 from starting the laptop & share me the error code.
sudipta2k21@gmail.com
Nov 19, 2009 | Dell Latitude E6400 Laptop
Dell E6400 onboard NIC cannot get network connection - "A Cable Is Unplugged". The laptop is undocked with CAT5 cable firmly attached.
I'd suggest updating the NIC driver in Device Manager. But, the message "A Cable is Unplugged" tells me that the NIC port, the CAT5, or the port where is is connected to your modem/router may be faulty. Try moving the cable to a different port on your modem/router, first. Then, try another CAT5. If still a problem, the NIC port is probably faulty. Hope this helps.
Jul 22, 2009 | Dell Latitude E6400 Laptop
Dell Latitude E6400 Notebook Logo
237 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
