Question about Magic Bullet Nutribullet Blender
Jar does not lock to operate - Magic Bullet Nutribullet Blender
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
I have a new KA blender. After washing I am not able to get the pitcher back into the locking collar to allow the couplers to fully engage. I have done it several times and it is just not working. I...
Please make sure the collar is on a firm flat surface (not on the blender). Check the silicon gasket is evenly placed in its groove in the middle of the collar. Lower the glass jar onto the collar lining up the gaps on the collar with the glass keys on the side of the jar. Holding the collar in one hand, twist the glass jar clockwise to lock into place. If this doesn't work it sounds like something is jamming the mechanism underneath.
Apr 05, 2011 | KitchenAid KSB560 5 Speed Blender
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
New gasket installed but jar still leaks...Does gasket go between jar and cutter or between cutter and screw base?
The gasket goes between the plate to which the cutter is mounted and the base of the jar. i.e., atop the cutter and contacting the base of the jar.
Charlie
Jan 12, 2011 | Waring Blenders
Hi, i am a culinary arts teacher. we bought the waring BB160 and used it for the first time today to make milkshakes. the canaster does not fit snuggly on the base. it can be shifted to the left or to...
I am not sure what you mean by "can be shifted" but the model does not have a locking mechanism to the base so the jar assembly can be easily removed once the mixture is done. As long as one does not take the jar assembly off while the machine is running (which could ruin the coupling and blade) you should be ok.
Nov 02, 2010 | Waring BB150S Work Top Blender
KitchenAid Blender Model KSB560GC0. Coupling is ruined. Looks to be a geared part at the base of the unit. [ top of motor ] Also there is a part that is geared at the bottom of the pitcher, attached to...
the older glass jar blenders were sold as a complete ***'y too.
no separate parts were available. i'm sure the stainless jars are sold in the same way...complete.
Jun 24, 2010 | KitchenAid KSB5 Professional Stainless...
KSB5600BO kitchenAid blender blades broke and l am looking to replace them but I can't find the right parts. Do I need to just by the whole Jar assembly?
You don't need to replace the entire jar assembly. Have you tried to contact Kitchensid. They make high quality appliances and will probably send you new blades for $0.
Apr 19, 2010 | KitchenAid KSB560 5 Speed Blender
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
Nov 29, 2009 | Blendtec Extra Carafe / Jar for the Total...
Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
Mar 19, 2009 | Oster Blenders
My blender doesnt lock
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Sep 12, 2008 | Black & Decker BL675 ProBlend Work Top...
Magic Bullet Nutribullet Blender Logo
27 people viewed this question
Top Magic Bullet Blenders Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
R.A. Ellis
R.A. Ellis
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
