Question about True 598-TSSU7218 SandwichSalad Food Prep Table 72 38 Long 3 Doors 18 Pans
How to properly install t-stat on TSSU-72-30M-B
  • 100 Answers
The same you remove the old one the new one goes on. Be sure to inscert to sensing bulb in the copper tube in the evap section. 1/4"nut driver and a phillips screw driver
Posted on Jun 27, 2015
Temperature setting True tssu-60-16
if you tried to adjust the temperature and the cooler continues to freeze the food then replace the thermostat attached to the control knob. Thermostats fail in different ways
Link=> HERE
APPLIANCE 911
Jul 22, 2016 | True TSSU-60-16-ADA Stainless Steel...
Can anyone tell me the proper installer configurations step by step for a 1f95-1277 big blue tstat to run my furnace/heat pump?thanks
If it aint for a heat pump then that stat won work. Has to have a heat pump stat to operate reversing valve
Jan 03, 2016 | Heating & Cooling
I got a true tssu-27 that won't cool what would be the problem with this unit?
Many times the air circulation across the condenser is the problem. Take a look at the condenser and make sure that the condenser fan is running and there isn't dirt or grease blocking air movement. There is also the obvious like a compressor that's not running or an iced up cooling coil. Is the compressor hot? Maybe an additional description would help. Are the fans inside the cabinet running? Good luck hope this helps.
Oct 23, 2014 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Feb 04, 2013 | True TSSU-60-16-DS-ST-ADA Dual Sided...
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
heatman101
Apr 24, 2010 | Honeywell Programmable Thermostat Heater
Water leaking into fridge
Open the back of the unit. There you will see a drain line. Use something to blow through it and clear blockage. If the drain is clear the drain pan may be rusted through. :)
Jun 05, 2009 | True TSSU-27-12M Refrigerator Commercial
Refrigerator keeps freezing up
check the door gaskets on the unit they could be leetting in too much moisture and that will cause the unit to form too much ice,
Mar 26, 2009 | True TSSU-27-12M-B Commercial Refrigerator
True 598-TSSU7218 SandwichSalad Food Prep Table 72 38 Long 3 Doors 18 Pans Logo
79 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
