Question about Danby DPAC13009 Air Conditioner
Danby premiere 13009 remote control doesn't work
Remote control doesn't communicate with the master
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: How do you install Danby
This whirlpool manual will give an idea: 10000 btu portable
Posted on Jun 26, 2011
  • 20 Answers
SOURCE: we bought the danby Premiere
check service tag on unit what is the amp rating on the unit does it exceed your breaker size??
Posted on Jul 03, 2011
Manual for Danby premier ddr30b1gp
The manual for the Danby DDR30B1GP Premiere 30 pint dehumidifier is available on the product page: https://www.danby.com/products/home-comfort/ddr30b1gp/ . Look in the right hand column. The current link to the manual is https://www.danby.com/wp-content/uploads/2017/03/DDR30B1GP__DDR45B1GP__DDR70B1CP_EFSOM_DM_Dec.19.2012_web.pdf .
I hope this helps.
May 09, 2018 | Danby Heating & Cooling
I need to purchase the remote control for Danby premiere dpac13009 Where I can find it ?
Ebay, only 1 available. $55 free shipping.
NEW Danby Premiere Room Air Conditioner Remote Control Transmitter A2529...
Appliance Parts Pros. $48 + shipping. I would call first because they don't have it in stock. Claim of 5-6 days may not be correct.
http://www.appliancepartspros.com/danby-dpac-remote-control-a2529-950-ap4556076.html
Repair Clinic $49 + shipping. Again call first because they don't have it in stock.
Remote Control A2529 950
Jul 27, 2016 | Danby Premiere 13,000 BTU Portable Air...
Need manual for premiere r410a
http://www.sylvane.com/media/documents/products/Danby-DDR5009REE-Owners-Manual.pdf
You will need a PDF reader such as Adobe Reader or one of the other free PDF readers. It is a PDF file and will not open as plain text.
Oct 20, 2014 | Danby DDR5009REE 50 Pints Energy Star...
No power to the DMCI master.
reset the DMCI master, test the power cord+power switch for faulty and replace use the multimeter.
Read your owner manual or download from www.retrevo.com
God bless you
Oct 20, 2013 | M&S Systems dmc1 Music/Communication...
Daikin brc2a71
This is a communication issue between the sub remote controller and the master remote controller.
This fault occurs when a remote controller that has been set to sub cannot see the master remote controller that has to be installed on the fan coil.
Please check the wiring for the remote controllers to ensure correct connections, also if there is only one remote on the unit ensure that the Main/Sub switch is set to Main.
May 18, 2013 | Daikin BRC2A71 - Simplified Individual...
The digidoor motor does not respond to the remote or the master wall mounted remote
Is it getting power? Use a multimeter and verify voltage. That a good place to start. Are the remotes and wall switch both powered by batteries or is the wall switch powered by AC/DC current? If both are in working order (power), are they both using a wireless type communication? Need a bit more info to make a correct solution.
Nov 03, 2012 | Televison & Video
The master door lock of my 2006 Odyssey doesn't close all doors any more. where is the problem? Have no clue!
You will need the system scanned for fault codes by the dealer or a shop that can test Honda products.
May 31, 2012 | 2006 Honda Odyssey
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
Open Questions:
What is the best physical configuation exhaust/drainage to use with dehumidifier mode to avoid room temperature increase? There are 2 drainage outlets on this model top and bottom. However the user manual doesn't mention about the top one. In AC mode, if I don't connect any drain hose, the unit fills up fast and stop. When the exhaust vents are connected outside required for AC mode only, I cannot use the bottom drainage hose because I have no drain nearby. Therefore I use the top drainage and add a bucket beside the unit. This setup works fine for hours in AC mode without intercuption and the bucket fills up with water fast. However the rooms gets too cold below 20C/68F while still quite humid +60%. But if I switch to dehumidifer mode with the same setup, the unit only runs for a few minutes, then stop completely for another 5 minutes, then turn into FAN mode which blows very humid air for another while and then turns the compresssor back ON for another 5 min. and the loop start over. After hours of operation, the bucket nearly has any water and the room humidity is the same if not worst. I thought the compressor was defective so I tried the dehumidifer mode without the exhausts vents connected outside and the bottom drainage hose as suggested in the user manual. This setup works continuously but does not remove much humidity vs. the amount of heats it generates. The unit has AUTO Mode which switch between AC and dehumidifier mode. So there must be a way to keep the same physical installation exhaust and drainage for both these mode, is there? Thanks
Jul 30, 2016 | Danby DPAC13009 Air Conditioner
See all Danby DPAC13009 Air Conditioner Questions
Danby DPAC13009 Air Conditioner Logo
77 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
