Question about iPhone Apps
What is linked in? - iPhone Apps
Where is fusible link located on a 2004 Hyndai Elantra?
There are nine fusible links in the engine compartment relay and fuse box: 120A FUSIBLE LINK (BATT), 30A FUSIBLE LINK (ABS 1), 30A FUSIBLE LINK (ABS 2). 30A FUSIBLE LINK (BLOWER), 40A FUSIBLE LINK (IGN), 20A FUSIBLE LINK (ECU), 50A FUSIBLE LINK(BAT), 20A FUSIBLE LINK (RAD), and 20A FUSIBLE LINK (COND). The passenger compartment junction block contains the 30A FUSIBLE LINK (PWDW)
Jul 20, 2017 | 2004 Hyundai Elantra
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
Source code for implementation of linked list using opengl in vc++
Source code:
#include
using namespace std;
class linklist
private:
struct node
int data;
node *link;
}*p;
public:
linklist();
void append( int num );
void add_as_first( int num );
void addafter( int c, int num );
void del( int num );
void display();
int count();
~linklist();
linklist::linklist()
p=NULL;
void linklist::append(int num)
node *q,*t;
if( p == NULL )
p = new node;
p->data = num;
p->link = NULL;
else
q = p;
while( q->link != NULL )
q = q->link;
t = new node;
t->data = num;
t->link = NULL;
q->link = t;
void linklist::add_as_first(int num)
node *q;
q = new node;
q->data = num;
q->link = p;
p = q;
void linklist::addafter( int c, int num)
node *q,*t;
int i;
for(i=0,q=p;i {
q = q->link;
if( q == NULL )
cout return;
t = new node;
t->data = num;
t->link = q->link;
q->link = t;
void linklist::del( int num )
node *q,*r;
q = p;
if( q->data == num )
p = q->link;
delete q;
return;
r = q;
while( q!=NULL )
r->link = q->link;
delete q;
return;
r = q;
q = q->link;
cout}
void linklist::display()
node *q;
cout for( q = p ; q != NULL ; q = q->link )
coutdata;
int linklist::count()
node *q;
int c=0;
for( q=p ; q != NULL ; q = q->link )
c++;
return c;
linklist::~linklist()
node *q;
if( p == NULL )
return;
while( p != NULL )
q = p->link;
delete p;
p = q;
int main()
linklist ll;
cout ll.append(12);
ll.append(13);
ll.append(23);
ll.append(43);
ll.append(44);
ll.append(50);
ll.add_as_first(2);
ll.add_as_first(1);
ll.addafter(3,333);
ll.addafter(6,666);
ll.display();
cout ll.del(333);
ll.del(12);
ll.del(98);
cout return 0;
May 19, 2011 | Computers & Internet
My firelight is corruptable
yess u can :
Try first : SRART - RUN - CMD - THEN WRITE CHKDSK E:
ENTER and wait..Try if it will open if not just email me and i will take care off it ar_pllana@hotmail.com
Nov 06, 2007 | SmartDisk FireLite 40 GB Hard Drive
iPhone Apps Logo
265 people viewed this question
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
