Question about Dishwashers
Aeg favorit 50830
30 error code
BIKER T
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
taran_2005
  • 10515 Answers
SOURCE: AEG Favorit dishwasher. Flashing error code 30.
Error 30 is an indication that the anti flood device has been activated.
As the machine starts up again when you tip it and drain the base this confirms that there is water getting into the base.
Pull the machine out, unplug it from the wall socket and take the side panels off.
You will have to run the machine with the panels off to look for the leak.
Please keep your hands (and the rest of your body) away from the machine whilst power is applied.
Once you locate the source of the leak, unplug the appliance from the wall socket before attempting to repair it.
Unfortunately, I can only tell you that the common leaks on these are from a loose nut on the salt container (take the cap off and check that the nut is tight) or from the wash motor hose.
Obviously, with the panels off you will be better placed to observe the leak.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 20, 2011
mastermaid
  • 502 Answers
SOURCE: AEG FAVORIT 443 Manual I need a manual. How to
Hi, I found the Favorit 443 manual here
Posted on Aug 19, 2011
AEG dishwasher Favorit 86450I displays error code AL7.What does it mean?
i was looking up some info about your dishwasher and this problem might be part of the control board or the pump not turning on in the dishwasher however if one is tech savy you can actually get a ardino board to run the dishwasher (seen on youtube)
Feb 23, 2017 | AEG Dishwashers
Error code 90
i90 error code means Check sum (model programming) MCF or Check sum CCF not OK, or in other words faulty electronics.
Dado
Feb 25, 2016 | AEG 23 in. Favorit 50750Vi Built-in...
Aeg favorit 88080 service code i30
In my case, it turned out that the faucet was completely clogged with scale deposits. Replacing the faucet solved the problem, so by all means, check this before you take any other action!
Jul 10, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Code i10 occurs
Do you know what is error i10 ? I have same
Jul 12, 2009 | AEG 23 in. Favorit 86070Vi Built-In...
Feb 02, 2009 | AEG 24 in. Favorit 3A Free-standing...
Code: C 2 ??
C2 error code means, that the drain is clutched.
Removed all dishwasher water with a cup.
Added a gallon of boiled water, waited 10 min and it worked again( so far).
Regards
Sigurd
Jan 28, 2009 | AEG 24 in. Favorit 80800 Free-standing...
Error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Mar 27, 2008 | AEG 24 in. Favorit 60870M Free-standing...
AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Oct 24, 2007 | AEG Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
