Question about IZH-Baikal IZH 46M Breech Seal Kit
IZH 46M Breech Seal Kit - IZH-Baikal IZH 46M Breech Seal Kit
Savage smokless powder muzzleloading rifle broken vent liner in breech plug is this a common problem also is there any upgrades for this are parts still available for this rifle any info would help
Check out these links and the bottom link
Precision Rifle Savage Vent Liners - Precision Rifle Home
https://www.prbullet.com/vl.htm
  1. Cached
  2. Similar
Savage 10 ML II Single Hole Vent Liners. The hole in the factory Savage vent liner measures .0305". By experimenting with a variety of breech plugs utilizing ...
Precision Rifle Home - the world's most innovative Muzzleloader Bullets
  1. Cached
  2. Similar
Precision Rifle - Manufacturer of the world's most accurate muzzleloader ... Savage Smokeless Muzzleloader - could it be the Ultimate? ... Savage Vent Liners
Cleaning frequency recommendation for a Savage muzzleloader
https://www.savagearms.com/firearms/cleaningmuzzleloader/
  1. Cached
  2. Similar
If you have fired either black powder or Pyrodex® through your rifle, use any good ... Thoroughly clean the breech plug and removable vent liner of fouling with ...
Vent Liner for Savage MLII and all Lehigh Breech Plugs - Lehigh Bullets
https://www.lehighbullets.com/.../vent-liner-for-savage-mlii-and-all-lehigh-breech-plu...
  1. Cached
  2. Similar
US$27.00 - ‎In stock Direct replacement vent liner for the Savage MLII muzzleloader and all Lehigh breech plugs. The domed head and computer modeled internal design improve ...
muzzleloading rifle broken vent liner in breech plug Google Search
Dec 19, 2016 | Optics
How do I replace a breech seal on a Crosman Phantom
Go to YouTube with that question and you should find a number of videos dealing with it.
Dec 22, 2014 | Crosman Optics
Baikal IZH 46M Leaks
you have guessed the problem correctly . keep using the OIL when needed .
Dec 14, 2017 | IZH-Baikal IZH 46M Match Air Pistol -...
Leaking pool pump
It is difficult to see exactly where the leak originates. Obviously the drips are coming from the front of the pump, but the leak may be elsewhere. I would suspect that the origin may be at the seal, because a breech in front of the seal would not allow the pump to catch prime.
This normally indicates that the pump has run for some amount of time with no water flowing through it. However it also is not clear if the pump is running or not.
In the case of an above ground pool, water may leak at any point that there may be a breech at any point, being that the pump is below water level.
Look very closely at the drip and try to follow it upstream to see if you can determine where the water is originating. Hard to troubleshoot based on available info.
Jul 01, 2013 | Pool & Spa
This is the izh 513m .177 rifle. It's brand new. I am not sure as of what to do and the hammer want budge and the trigger won't pull. The barrel has no tension and it won't go up like its supposed to.
This could be a factory safety that the hammer and trigger do not move while in the cocked position. The barrel may be locking down purposely. Look near the spring or in the path of the barrel where it folds back up and look for a release button. What do you see?
Jan 26, 2013 | Sport & Outdoor - Others
IZH-Baikal IZH 46M Breech Seal Kit Logo
42 people viewed this question
Top IZH-Baikal Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an IZH-Baikal Tool and Hardware - Other Expert? Answer questions, earn points and help others
