Question about Whirlpool Refrigerators
Et14jk refrigerator light doesn't work
Refrigerator is plugged in and running. Light burned out and was replaced but does not work. Replaced twice with different bulbs. Problem not solved.
  • 1314 Answers
SOURCE: Lost light Whirlpool Regal refrigerator
two ways might first un plug the unit take the bulb ou and with your finger pull up on the contact inside the light socket ***** the bulb back in and try it if that doesn't work unplug the unit and with a mall screwdriver pry out the switch un plug one wire and with a meter check it to see if its working right or just replace it
Posted on Mar 12, 2008
SOURCE: dispenser light very dim
Put a new York Bulb for your tired computer. Sorry! Can't answer this.
Posted on Sep 23, 2008
tborn6
  • 700 Answers
SOURCE: Refrigerator light doesn't work
then tyr and replace the door switch on the refrigerator side. they are relatively inexspensive to buy and are real easy to replace.
Posted on Feb 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Posted on Mar 04, 2009
Sea Breeze
  • 4654 Answers
SOURCE: refrigerator works but no interior lights new bulbs
I have the repair manual and will be back soon. I am looking over the possibilities.
Posted on Apr 30, 2009
Suddenly, No tail lights, brake lights, turns signal or back up lights At 83000 miles, 6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen...
just look for the blackened/burned pin on the rear light plastic connector and sand it down to re-establish a good electrical connection and save yourself $800 big ones on replacing the multiswitch.
Jun 26, 2011 | 1999 Chevrolet Venture
Kenmore sidexside light burned out. replaced bulb, won't light.
There is a plastic switch that works the light in the door jam. Unplugg the fridge before popping this plastic switch out. I would order one first but if your light fixture is in good shape and not burn on the inside and the wires look good it is most likely the door switch. The door switch is just like an on off switch for any light its just spring loaded to turn on when the door opens. good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Burned out light in refrigerator. Replaced with
lube the light base with silcone and tighten . it has a rubber boot to seal it and it sometimes won't let the base of light tighten and touch contacts. **** ..
Jan 10, 2010 | Refrigerators
I have a 2002 Trailblazer. I have changed the
check the wires to the plug for damage that could cause a short.do not touch the glass on a halogen bulb-the oil from your fingerprint can cause a 'hot spot' leading to premature failure. clean 'dirty' bulbw/alcohol & a clean cloth.
Oct 06, 2009 | 2002 Chevrolet TrailBlazer
Oxegen sensor keeps burning out
the converter needs replaced the ceramic has broken down. this will fix the problem.thanks for clearing up what code
Feb 15, 2009 | Hyundai Sonata Cars & Trucks
Es300 lexus tail light alarm center portion out! no burn bulbs
We have a similar problem with a loose bulb. We tap in the light external light fixture and the bulb re-lights and the idiot light goes off.
Dec 30, 2008 | 2001 Lexus RX 300
Fog lights out on 2001 passat.
The only way a lot of bulbs can burn out at once is overvoltage. Check your charging voltage with the car running, using a multimeter. Should be 13.8 volts; with the car off, about 12.6.
Jun 02, 2017 | 2001 Volkswagen Passat
Dispenser light very dim
Aug 31, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Oven not working
In this case, I would check the following:
  1. Make sure the oven is receiving power. Turn the power off and on at the circuit breaker.
  2. Pull the oven out of the wall and inspect the control boards. Look for burned areas. The power area could have burned out or the control card probably burned out.
  3. Personally, I think that in this case, the are that the whole computer card will need to be replaced. It runs over 100$ in parts.I think this because it's happened twice to me -- once when we had a power surge in the house, another time when I simply replaced a light bulb in the oven.
I hope you will post back what the actual solution was.
May 19, 2008 | Fisher and Paykel AeroTech Double OD302...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
