Question about OCE Office Equipment & Supplies
Misfeed in copier - OCE Office Equipment & Supplies
2 Suggested Answers
  • 87 Answers
SOURCE: misfeed in finisher
just check propely any small piece of paper is in machine or any sensor in paper path is disturbed check all sensors and there levers .or take a hard file cover and from bypass with ur hand pull it in copier and send him to toward exit tray .just off copier first and do this .
Posted on Dec 16, 2008
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
It is showing the following signs U1, A,C
look my dear that is misfeed positions ok a; that mean first tray misfeed and tray2 c; that mean misfeed in fuser unit u1; mean misfeed in sorter
Jan 08, 2011 | Ricoh FT5832 Copier
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
Ricoh Aficio 250, clear misfeeds at w and finisher
Clean the sensors in this parts and try reset the SC codes:Enter in the SP mode press 5-810 (SC code reset)select 1.Then hold down the Photo mode key and the +key at the same time for at least 4 sec.
Sep 23, 2009 | Ricoh Aficio 250 Copier
Misfeeds
We lease the copier and have a maintenance contract. We call for a technician to come out and fix the problem. I was trying to find out if there was something preventive that we could do to avoid the misfeeds. For instance, maybe a particular type of paper (brand) is recommended. We use different brands but all are 20lb bond (some recycled, some not). We attempt to keep the paper from absorbing humidity, keeping it in its wrapper until use. Often I think it is that the sensors in the copier get "dusty" and then don't function properly. The user cannot get to these sensors -- that takes a technician.
Mar 03, 2009 | Kyocera Mita Office Equipment & Supplies
Misfeed in finisher
finisher is the unit attached to the copier on the left.
open door and look for any green handle, these are what you need to move to locate the jams
Oct 19, 2008 | Toshiba E-Studio 3511 Color Copier
Misfeed in finisher
Oct 19, 2008 | Toshiba e-Studio 232 Black and White...
Minolta Di520 false misfeed
Try resetting the copier, with the copier powered on open the front door remove small cover on right hand side press reset button close front door, the machine should boot
Feb 06, 2008 | Minolta DiALTA Di520 Laser Printer
Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Sep 16, 2007 | Sharp AR-M455N Copier
E350 misfeed on print/copy 2nd page
Does this happen from all cassettes or only one? What are you getting for a jam location??
May 11, 2007 | Toshiba e-Studio 350 Copier
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
