Looking for examples of opc communications written in c++
Our Glass sheet ID number not Transferring in OPC server. Between Clients. Especially issues with Read/ Write OPC communication. Please give us some solution for this.
Posted on Feb 06, 2010
  • 413 Answers
OPCServer MyServer = null;
OPCGroups MyOPCGroups = null;
OPCGroup MYOPCGroup = null;
MyServer = new OPCServer();
MyServer.Connect(ProgID,NODE);
// till here ok
MyOPCGroups =(OPCGroups) MyServer.OPCGroups;
// but when I tried to create the OPCGroups I am getting casting error saying:
// "Unable to cast object of type 'OPCAutomation.OPCServerClass' to type 'OPCAutomation.IOPCGroups'."
MYOPCGroup = (OPCGroup)MyOPCGroups.Add("MyGroup");
Posted on May 08, 2009
What is parsing the package? I cant install mobogenie.
"Parsing the package" means decoding that part of the software installation file. Either it is in a file format your operating system doesn't understand, or the file is corrupted.
In general, parsing means picking apart a piece of verbal or data communication to derive its meaning. Example usage: "Parsing legislation written by lawyers is often difficult."
May 08, 2014 | Computers & Internet
Im trying to write a code in matlab that accepts a character corresponding to the one above buttons(keypad-0-#) and genrates the appropriate dual-tone frequency
Provides an example Server / Client written in MATLAB that utilises the ability to call Java inline to perform message communication using TCP/IP.
Importantly it does not require any pre-compiled DLLs or force you to compile some MEX c-files. Nor does it require any additional toolboxes Its all contained within the .m files.
To use the example:
- Start 2 instances of MATLAB
- in the first execute the following:
message = char(mod(1:1000, 255)+1);
server(message, 3000, 10)
- in the second execute the following:
data = client('localhost', 3000)
Aug 20, 2013 | Computers & Internet
No screen and the power and opc light flash on lc-46e77un tv
Final Up date, The TV is fixed, with my problem it was found that the units Mainboard was defective. If you go to replace your Mainboard MAKE SURE THAT YOU PURCHASE THE CORRECT BOARD AND VERSION NUMBER OR IT WILL NOT WORK...... for example KE833 XE833WJ and the most important part, look for the version on the White lable markings, mine was FM11S it will be some FM number that will be used on your Set. Hope this helps you solve your problem.
Aug 15, 2012 | Sharp AQUOS LC-46E77UN 46 in. LCD HDTV
I want searial no.
Each device on computer networks have serial numbers. For example, networks that are establshied with modems with routers would hav each manufactures serial number lcoated on the device. Observe the devices written logos to ascertain amongs the details provided from manufacturer the serial numbers.
Feb 21, 2011 | Computers & Internet
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
What is (SVC E9 Error)
Hi there
The error indicated on the 8008, ‘SVC E9’ indicates the printer is not detecting the OPC belt as rotating in the printer. The printer ‘looks’ for two black squires on the left side of the OPC Belt (as viewed from the front of the printer) if the printer does not ‘see’ black squires the printer indicates the SVC E9 error.
If the printer is displaying the SVC E9 error the most likely cause is something to do with the OPC Belt, normally removing the OPC belt from the printer then re-seating the belt would resolve the problem in most cases, as the OPC belt may not be locating correctly in the printer.
Unfortunately you have already removed the OPC Belt from the printer without resolving the problem, it may however be worth removing the OPC belt again and to look at the green reflective surface to see if there any damage or if the green surface is fairly central and is no skewed or bent in any way.
Depending on which position the OPC belt stops in you may see the black squares down the left side of the belt, if you can see these and they don’t look damaged or scratched the printer should detect the OPC belt ok, so the problem may lie with the sensor on the printer its self.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | TallyGenicom 8008 Laser Printer
OPC belt has 78% left -cant rid the problem
Look at the OPC belt edges, there's a shiny spot that passes thru a sensor, a can of air should blow out the sensor, carefully! When the sensor can't see the timing spot you get that error. You may have to replace the OPC since companies are imbedding a chip that tells the machine when they're used up.
Sep 01, 2009 | Brother MFC-9420CN All-In-One Laser...
TALLY GENICOM 8008
The SVC E9 error indicates a 'BELT MARKER' error.
This means the printer is not detecting the OPC Belt as rotating.
This error can be caused by a damaged OPC belt, you can check this by removing the OPC belt from the printer and look at the OPC belt it should have a smooth green coating if there is damage to this belt it may cause this error.
The error can also be caused by a damaged 'Transfer Belt' when the OPC belt has been removed from the printer look inside the printer where the OPC belt used to be located you should see a black belt towards the back of the printer, if this belt is damaged it can also cause the error.
Ensure the OPC Belt locates in the printer correctly.
If the OPC belt and Transfer belt look to be free from damage and a are located correctly in the printer you may have a faulty belt marker sensor or faulty OPC belt.
You can try substituting the OPC belt for an alternative one if you have this available to see if you can narrow the problem down to the sensor.
Jan 23, 2009 | TallyGenicom 8008 Laser Printer
I own a Tally Genicom 8008 Laser printer. From the last print and after it appears the message: SVC E9 ERROR
The error indicated on the 8008, ‘SVC E9’ indicates the printer is not detecting the OPC Belt as rotating in the printer. The printer ‘looks’ for two black squires on the left side of the OPC Belt (as viewed from the front of the printer) if the printer does not ‘see’ black squires the printer indicates the SVC E9 error.
Jan 17, 2009 | TallyGenicom 8008 Laser Printer
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Computers & Internet Logo
866 people viewed this question
David Payne
David Payne
