Question about Sharp LC-29LE440M Multi-System LED TV
No display to lcd back light is ok
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
  • 8457 Answers
SOURCE: power light blinking green and cannot turn off or display anythin
power inverter board is dead.
need a new one.
Posted on Sep 14, 2009
SOURCE: I need a diagram for lcd tv Sharp LC-26SB14U.
I have a sharp LCD (LC-26SB14U) which I purchased one year ago and today the sound stop working as I was watching the olympics. Any idea how to fix this problem as the warranty is only good for a year.
Thanks, Bob
Posted on Feb 27, 2010
bshldn
  • 736 Answers
SOURCE: LC-32SB24U 32 in. LCD TV: need the liquid crystal display for tv...
It is in stock at MCM Electronics for $867.64
http://www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-/R1LK315T3GW30Z
Posted on May 20, 2010
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 01, 2011
Testimonial: "Helpful"
Samsung champ duos c3262 no display forums fix
many reasons are major cause for no display,blank display,scrambled display. In samsing champ duos c3262 no display problem terouble shooting.first connect with charger no charging logo on screen.open your cell phone and clean pcb and lcd connector with corbon tetra cleaner(ctc)dry normal.problem not solve then try seen lcd with lamp if display is shown but no light make light jumper or change lcd.lcd ok and new 100%working condition please be care fully check lcd connector.no display no luck final heat or replace display controller ic.
here is the light ic jumper if your lcd is black and now lights.
click on link for jumper ways by image. Samsung champ duos c3262 no display jumper Phonetolls
Jan 04, 2015 | Samsung Cell Phones
Acer as3810t no display
OK, best thing to do is test the external video port with a desktop monitor. The laptop will have a Fn key (function) commonly blue in color. The display icon in conjunction with the Fn key will switch between the 2 displays. Common issues with laptop displays is the back light inside the LCD display of the laptop. Power on laptop in a dark room and sometimes you can see the display, just slightly.
If you can see it, replay or have somebody replay the back light in the display. Was This Helpful? Yes OR No *Please vote yes if this helped you
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 07, 2014 | Computers & Internet
MY PHONE SAMSUNG MONTE GT5620 IS SHOWING DISPLAY DIM I ALREADY CHECK THE BRIGHTNESS SETTING BUT IT IS OK...TELL WHT I DO
It sounds like the inverter for the back light is going out. the backlight is inside the lcd display. you can either buy a new lcd and replace, or have a shop do it. or if you have insurance on phone i suggest that first. Good Luck
Nov 29, 2013 | Cell Phones
Backlight burned out, how do I replace it?
The back light is typically an integral part of the LCD display, so you may have to replace the entire display. On some displays, the touchscreen and back light connections are separate from the display and on some displays, these connections are soldered to the LCD display. Trying to take apart the LCD display just to change the back light can result in breaking the LCD display. You are better off just replacing the entire display if you can find it for that model.
Oct 15, 2013 | Garmin GPSMAP 176C GPS Receiver
My flavia 400 lcd is bad
Likely not the display itself but if so the cost of that part is more than the cost of a new set.....
Dec 03, 2012 | Televison & Video
W200i-keypad light ok,no display light
its hardware fault i think lcd fault try to change it
Feb 12, 2011 | Sony Ericsson W200i Cellular Phone
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
I got a hp pavilion dv 3000 laptop and changed the lcd and video
Just plug an external monitor and conrm display is ok or not. If it is ok, you have connectted the back light or back light cable incorrectly.
Else mother board - back light connectivity is not there, check it
Jan 15, 2010 | HP Pavilion dv6000z Notebook
The view screen is black and you can't see what you're taking the pic. Battery is ok
If camera shows Menu item or any on-screen display in LCD but no live view to take picture then it can be either aperture problem or defective ccd imager.
And if you do not see any display icon in LCD then of course LCD section is bad or LCD back light is Off for some reason. Try to see faint image in LCD if it is totally blank by pointing good amount of light with flash light or some thing.
Oct 16, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
LCD display is black
First fault may be in the back light panel which is behind the LCD display unit. If the felexible connector is proper,then there should be the white florescent light. If the light is OK,then look for a fault in LCD section. We can provide the service manuals and spares.
Sep 05, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Sharp LC-29LE440M Multi-System LED TV Logo
113 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
