Question about GE JVM1190 Microwave Oven
I need dimensions for the ge profile microwave #JVM1190BY002
drumbanger
  • 1199 Answers
SOURCE: GE PRofile Microwave runs but no heat
This is a sure sign that the magnatron needs replaced ( This is what heats the food!) replace and all will be good again!
PLEASE rate my response to your question
Thank
You!
Posted on Jan 10, 2009
stonephoenix
  • 563 Answers
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
SOURCE: NEED TO REMOVE WALL MOUNTED GE JVM1190BY002 MICROWAVE
I also have a JVM1190 and was baffled as to removal. My very handy brother solved it in two minutes. Above the door and keypad there is a long grill secured by two small squarehead (Robertson) screws. Remove the screws and grill and you will see on either side of the opening a long bolt. They go through to the back of the microwave where the support plate attached to the wall. The bolts have a slot in the middle for a flat blade screwdriver. Simply turn the bolt to release from the back plate. Make sure there is a helper underneath as the microwave is fairly heavy. Do the reverse for re-installation.
Posted on Feb 08, 2009
SOURCE: GE Profile microwave remove top grill
On models with two screws on top of cabinet, you must first remove these screws and then
1) open door fully
2) gently tap grill at microwave top on the right hand side - taping or moving grill to the left.
The grill tabs will then disengage from the slots at the bottom edge of the grill.
Posted on Mar 27, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Posted on Jan 11, 2010
What are the dimenisons for the GE microwave JVM163WB004?
Jaquetta, best that I can find from GE's website is the following
Width: 29 7/8"
Depth: 15 1/16"
Height: 16 15/32"
Hope this helps!
Jul 18, 2014 | GE Microwave Ovens
I need the dimensions of the GE Spacemaker XL Model JVM1653WH01
For dimensions look at the GE Appliance web site at: http://www.geappliances.com/ then search for JVM1653WH01
This will take you to the product information page for the JVM1653WH 1.6 Cubic Foot Over the Range Microwave Oven with weights and dimensions, installation instructions etc.
Oct 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
After the GE JVM1190BY002 Microwave stops its microwave sequence the fan motor above the touchpad just sits and hums but doesn't shut off.It still heats food corectely and it stops humming when I open...
You should first be sure your filters are clean and that your ductwork is clear.
See this link for a bulletin that may address your problem.
Otherwise, see this link in case you have a sticky door switch or relay.
You can find helpful GE exploded views and order GE parts here, and download GE owner's manuals and installation instructions here.
Oct 20, 2011 | Microwave Ovens
Need exact dimensions of GE JVM1460
If this link does not work paste it into a search window and then click the link:
JVM1460WA-GE Profileā„¢ SpacemakerXL 1.4 Cu. Ft. Microwave Oven
GO to this link: http://www.geappliances.com/service_and_support/literature
Then type in the model JVM1460SA001
15 & 3/4" high 16 & 1/2" hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | Microwave Ovens
Need to replace lamp in GE Profile microwave model JE1590SH02
PMG!!! I called GE and was told that changing the light bulb is not a consumer replaceable part!!! Are you kidding me!! She told me I had to have a GE tech come out. Makes you want to buy GE appliacnces, right!
Mar 01, 2010 | GE Microwave Ovens
No power
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 02, 2009 | Maytag MMV5207A Microwave Oven
Nov 15, 2008 | GE JVM1190 Microwave Oven
NEED OPERATION MANUAL FOR 1998 MICROWAVE-CONZECTION OVEN mODEL JVM1190BY002
Go to geappliances.com. Select "Use and Care Manuals" under the Search drop down menu. Type in your model number in the adjacent window and select "Go". Your manual is available in a downloadable .pdf format. I hope this helps you.
Jul 23, 2008 | GE Microwave Ovens
GE JVM1190 Microwave Oven Logo
23 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
