Question about Faema Emblema
We have a Faema X1 that is not heating up. It shows E058 error and is not heating up; pressure is 1.7 bar. Heating elements are all ok and the level probe is all cleaned up from scales. What is the possible cause of this coffee machine for not heating up?
We have a Faema E92 Elite, 3 head. The display keeps giving an error code: Boiler overpressure E1. Already replaced the heating element (the gasket as well). How do we get rid off the error message?
You have one of two things going on here, the boiler is really over a safe pressure (very dangerous condition if error is for real) or the pressure sensor is malfunctioning. For safety sake I would have a professional look into this, a boiler explosion is a very dangerous.
Nov 29, 2016 | Washing Machines
Zanussi ZWD 1271 W - Error 33 (E33) machine drains after approx. 6 minutes of cycle - skips from 'wash' to 'drain' in the progress bar. Replaced with a new variable thermostat - hasn't worked! Help!
E33 - Inconsistency between level on electronic
pressure switch and level on anti-boiling pressure
switch 1(fault persists for at least 60 sec.).
  • Pressure switch defective
  • Electrical current leak between heating element and ground; Heating element; Wiring defective;
  • Main board defective.
  • Water circuit;
When is this fault occurs than will be performed emergency drain procedure, cycle stops with door unlocked.
Dado
Sep 24, 2015 | Zanussi Washing Machines
Repair heating element feama e97
Are you installing a new element or do you need to get a new one make sure you get an element gasket as well. Element is on right side of machine. Drain water 14mm plug under boiler. There are 4 wires on element two labeled 3, and one labeled 1, the other labeled 2. Element has 4 coils in two loops, top loop and bottom loop. 1 on top loop 2 on bottom loop the 3's on the other side.
Jan 16, 2013 | Faema Smart A2 Automatic Espresso Machine...
Should the water level be above heating element
The full water level will be 1/4 to 1/8 inch below the heating element. The water fills on a timed basis so the exact level depends on incoming water pressure.
Mar 06, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
How do I check my hot water element?
1)Locate the upper heating element in the top access. The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to the disk.
  • 2)Set your ohm meter to the X1 or RX 1 scale to measure the continuity of the heating element. Touch each of the ohm meter probes to each of the terminal screws on the heating element. A positive reading indicates a good element. If there is no reading, the element is faulty.
  • 3)Test for a possible short in the heating element with the ohm meter. Touch one ohm meter probe to one of the heating element terminals. Touch the other ohm meter probe to the bracket that secures the heating element. If you get a reading of zero, the element is good. If there is any positive reading on the scale, the element is grounding itself and will require replacement.
  • 4)Test the lower heating element exactly as the upper heating element.
  • 5)Place the access doors back on the water heater tank, and secure them with the screws.
  • Good luck
    E.CUADRA
    Dec 03, 2011 | Heating & Cooling
    Machine keeps stopping and showing fo5
    ALARM CODES
    E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
    E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
    E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
    E22 Problems with water drain during drying or drying
    condenser blocked E20 Heating phase skipped 8.5
    E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
    with door closed 8.6
    E32 Incorrect calibration of analogic (electronic) pressure
    switch --- Cycle PAUSED 8.7
    E33
    Incongruency between level of analogic (electronic)
    pressure switch and level of anti-boiling pressure
    switch 1
    --- Cycle blocked
    with door closed 8.8
    E34 Incongruency between level of electronic pressure
    switch and level of anti-boiling pressure switch 2 --- Cycle blocked
    with door closed 8.9
    E35 Water level too high --- Cycle blocked with door
    closed and water drain 8.10
    E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
    with door closed 8.11
    E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
    E38 Pressure chamber blocked --- Heating phase skipped 8.12
    E41 Door open E40 Cycle PAUSED 8.13-14
    E42 Problems with door closure E40 Cycle PAUSED 8.15-16
    E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
    E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
    E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
    with door closed 8.19
    E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
    closed (after 5 attempts) 8.20
    E52 No signal from tachometric generator --- Cycle blocked with door
    closed (after 5 attempts) 8.21-22
    E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
    with door closed 8.23
    E54 Relays (motor) contacts faulty --- Cycle blocked with door
    closed (after 5 attempts) 8.23
    E61 Insufficient heating during washing --- Heating phase skipped 8.24
    E62 Overheating during washing --- Drain, end of cycle 8.25
    E63 Insufficient heating during drying Heating phase skipped 8.26
    E64 Overheating during drying --- Heating phase skipped 8.27
    E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
    E71 NTC wash sensor faulty --- Heating phase skipped 8.29
    E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
    E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
    E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
    (door open) 8.32
    E85 Circulation pump faulty --- Drain, end of cycle
    (door open) 8.33
    E91 Communications error between main PCB and user
    interface --- --- 8.34
    E93 Configuration error E90 Cycle blocked 8.34
    E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
    EF1 Drain filter blocked LED-EF0 --- 8.35
    EF2 Excessive detergent LED-EF0 --- 8.35
    Regards David Marsh
    Oct 22, 2009 | Washing Machines
    Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
    Hello
    ALARM CODES
    E33
    switch 1
    --- Cycle blocked
    (door open) 8.32
    (door open) 8.33
    Regards David Marsh
    Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
    Error codes
    Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
    May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
    Faema Emblema Logo
    Top Faema Coffee Makers & Espresso Machines Experts
    richie46
    ray gallant
    Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
