Question about Dell W2306C 23 in. HD-Ready LCD Television
Tv is locked - Dell W2306C 23 in. HD-Ready LCD Television
If my TV acts like it is locked but is not then what is wrong with it?
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
• Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
•Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
• Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step .
Jan 08, 2013 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
MY TV IS LOCKED WITH A CHILD LOCK AND I LOST THE REMOTE TO UNLOCK THE TV PLEASE HELP.
Goto the near service center and a new remote of your tv brand and unlock your tv by child lock. its the simplest solution for your problem
Jan 06, 2011 | Televison & Video
How to unlock Hisense Tv model TC20FS16
Hello
Press the LOCK button to lock or unlock the TV.
When the TV is locked, the screen will turn to blue background, and nothing can be viewed unless you press
LOCK again to unlock it.
OK
[Sometimes you may need to press the LOCK button more than 5 seconds contnously to unlock the TV]
OK.
Jan 02, 2011 | Hisense TC24FS2H TV
Locked tv set model f19421
These are the instructions on locking and unlocking the control panel for your TV: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 12, 2010 | RCA F19421 19" TV
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
TV locked with blue screen
Try resetting the TV to factory settings thusly:
Turn on the TV. While holding down the RESET button on the remote
control, press the POWER button on the TV. (The TV will turn itself off, then
back on again.) Release the RESET button.
Owner's manual available here:
http://www.docs.sony.com/reflib/docget.asp?manualid=9635&template_id=1&region_id=1&DL=
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
V chip codes
LauriJo...
From the back of my Mitsubishi Owners Manual, Appendix A
"Bypassing the V-Chip Lock
After you set the lock, you need your passcode to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip Lock menus.
If you forget your passcode, you can view the locked TV without entering your passcode. This is done by pressing the number 9 and QV buttons on the TV remote control at the same time when your passcode is requested. This process temporarily unlocks the TV.
When entering the V-Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode."
I hope that helps you.
Nov 02, 2008 | Mitsubishi WD-52526 LCD TV
Sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Aug 12, 2008 | Sanyo DS24205 24" TV
Panisonic TV all locked up
Any other developments (or lack thereof) after our Live Chat?
Regards.
Mar 20, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Child lock on tv
i did child lock in my tv n my remote also not working plz tell me how to open tv now i
Jan 15, 2008 | Philips Magnavox 27MS343S 27" TV
Dell W2306C 23 in. HD-Ready LCD Television Logo
22 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
