Question about Toshiba Satellite 1715XCDS Cooling Fan (k000882360) Laptop Cooler
Message keeps popping up saying Turn off computer, problem in cooling system
Cooling fan overheating, message keeps popping on screen saying to turn off computer and return for service
  • 39 Answers
You need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Posted on Feb 22, 2015
  • 176 Answers
SOURCE: toshiba cooling system
If u have a laptop (that's what i found out that toshiba Qosmio is ) then is no problem that the fans stop (as long as the temp. is within the normal working margins ). U might have a setting problem - a bad software, managing the cooling system; - a bad BIOS setting regarding system temperature protection; - or the temperature detectors malfunctions, and must be changed (if possible)
Posted on Jan 18, 2008
  • 95 Answers
SOURCE: System warning pop-up
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Posted on Jun 09, 2008
VonZeppelen
  • 60 Answers
SOURCE: Toshiba Satelite M10 cooling system not working
If you DO NOT hear the fan running, have it looked at by a professional. Your fan may have died. If you can hear the fan running, blow out the fan exhaust port in the opposite direction of normal air flow. Especially on lap tops, the heat sink cooling fins become completely clogged with dust. When this happens the processor overheats causing it to run slow and eventually shuts itself down to keep from going super nova. You should blow it out at least once or twice a year. Also, if you use your laptop on the couch or in bed, place it on a hard surface like a cutting board or something similar that will allow air to flow underneath the computer. This will also help prevent dust from the cushions or blankets and such from clogging the cooling fins on the heat sink faster than usual. Remember blow it out in the opposite direction of normal air flow. You want to blow the dust out the same passage it came in through.
Posted on Feb 21, 2009
  • 4340 Answers
SOURCE: i have bought a new
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Posted on Feb 26, 2011
SOURCE: Repeatedly getting warning there is
Hi ecarusiiii,
This means that your system is experiencing heating issues. I highly suggest for you to take your Cooling system to the shop where you purchased it and get the issue fixed there.
your system needs to be Serviced.
i hope this helps.
Posted on May 16, 2011
My cooling system keeps giving error messages
you have to service air vent and check cpu cooler fan is working.
Oct 01, 2017 | Toshiba Portege R705P35
Screen turns off but computer stays on. Also the area were the cooling fan gets extremely hot.
It could be overheating. The screen turn-off is possibly a failsafe mechanic to keep the circuitry from developing a fault from the high heat.
Try leaving it to cool for a while, maybe an hour or two, then turning it on. When the screen turns off try holding down the power button, then turn the laptop back on. If the screen turns back off after a much shorter time than from when it was cool, it's probably overheating which could be from a build-up of dust in the fans, meaning you'd need to get it over to a repair centre to fix it.
However, it could also be a software issue. It's worth running a virus scan using AVG or avast, both of which are free. It's always possible malware is causing your issues, though it sounds like a hardware problem to me.
Mar 05, 2011 | Compaq Presario CQ60-220US PC Laptop
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
OVERHEATING
sounds like everything is working right but the computer is not turning the fan on. i would say the temp switch for the fan. it sends a signal to the computer to turn it on. it is very cheap and is the most common and likely problem.
good luck and please ask any more question you have
Sep 26, 2009 | 2005 Ford Ranger
Jun 08, 2008 | Toshiba (K000016310) Cooling Fan
Samsung q1 black screen
That would be normal, as the variable speed fan comes on only when the computer is under load.
What is not normal is that the fan is not coming on when the computer overheats.Or that the fan is not cooling enough when computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Mar 12, 2008 | Samsung Q1 Tablet PC
Toshiba Satellite 1715XCDS Cooling Fan (k000882360) Laptop Cooler Logo
223 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
