Question about HP Designjet T790 Inkjet Large Format Printer - 44" - Color
Error 21.2:13, restart, if problem persist call hp support
E 0000808-0000
This is 8 months old machine Canon 2420L, with 11000+ prints
Now we are getting this error message "
"Restart the machine. If problem persists call service rep
**E000001-0000 "
after restart below error message is displayed
**E0000808-0000 "
Aug 05, 2013 | Canon Digital Copier/Printer
Error code 21.1:03
there is a solution in the user manual but the best place is to go to office equipment repaerer tyhats vlokal to you
Jun 17, 2013 | HP DesignJet Z2100 InkJet Photo Printer
Service error 79
79 Error Turn off then on
Description
The product has experienced an internal firmware error. Under most conditions, the product
automatically restarts.
Recommended action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power
and wait for the product to initialize.
If a surge protector is being used, remove it. Connect the product directly into the wall socket. Use the
power switch to turn the product on.
If the error persists, contact HP. See www.hp.com/go/LJColorMFPM375 or www.hp.com/go/
LJColorMFPM475 or the support flyer that came in the product box.
Mar 17, 2013 | HP LaserJet Pro 400 color MFP M475dw -...
We use hp T770 HDD, error massage 79.03 when loading, after show preparing print system massage in a few minutes. ask for restart but after restarted the problem persist. please kindly help us if there any...
79 errors are often linked to firmware. Unplug the printer from power as well as any network or USB cables you may have plugged in. If the printer will restart without an interface cable connected then it is likely a bad print job. Clear all jobs from the print queues and then plug in the interface cable. If printer continues to stay at ready, download the current firmware and install it. This should resolve the problem.
May 25, 2011 | HP DesignJet Z2100 InkJet Photo Printer
Hp 770 have an error ------21:13--- Please help me
21 error indicates a problem with the service station. You need to make sure that there is nothing stopping the proper movement of the service station such as a piece of paper. If you do not find anything there, shut the machine off completely and then restart. If the error returns, you will need to run the service station diagnostics, I do not have the procedure in front of me right now but if the error persists, post back a comment and I look it up for you.
May 19, 2011 | HP DESIGNJET T770 Printer
I have hp laserjet2420 printer with ERroR 52.20
Restart the printer and try printing again. If the error persists, it is either the scanner assembly or the ECU. More often the scanner fails on printers than the ECU.
May 15, 2011 | HP LaserJet 2420 Printer
I am not able to print it shows "52 scanner error restart printer
From HP Support:
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the all-in-one to initialize.
If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket. Use the power switch to turn the all-in-one on.
If the error persists, contact HP Customer Care.
Hope this helps.
Jul 29, 2009 | HP LaserJet 3055 All-In-One Printer
When I turn on my HP designjet T 1100 I get error message 08:11
turn off printer, disconect hdd from pcb, turn on then printer beeps, turn off mount hdd back, turno whait ;).
Mar 19, 2009 | HP Designjet T1100ps Printer
HP Designjet T790 Inkjet Large Format Printer - 44" - Color Logo
48 people viewed this question
Seeker5211
Seeker5211
