Question about Pioneer DEH-1730R CD Player
Deh1730r can you activate an aux in..; - Pioneer DEH-1730R CD Player
Having trouble getting cleaner to activate. Should cleaner be the same AUX # inside and outside?
make sure dip switches on board ok filter pump must run when cleaner is on or will ruin pump
Jul 11, 2017 | Pool & Spa
The AUX button says SAT 1, SAT 2, AND SAT 3. It does NOT say AUX Line In and does not recognize anything plugged into the aux port. What can I do to get the AUX port working???
Make sure whatever is plugged into the Aux port is the proper size and configuration (2-lead, 3-lead; 3.5mm, etc) as far as the cable, is properly seated (not so big that it doesn't fit all the way in) and that the device is on. Most Aux inputs don't activate unless there is an active signal coming in.
Apr 02, 2015 | 2007 Ford Edge SEL
How do I reverse a lockout of aux 1 polaris?
check to see if repair man disconnected that aux if so plug back in if not go to system set up to activate that aux
Jul 07, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I'm plugging in an active speaker to aux 3 of my fx16ii, but it doesn't work. I have it set up the same as aux 1 and 2 where I'm also running active speakers (for monitors). Am I missing...
If you look at the signal flow diagram in your user manual, you will see that while AUX 1 and 2 can be selected are PRE or POST fader, AUX 3 is POST fader only... this means that the channel faders control the AUX3 level as well as the aux out level. Make sure you use TRS balanced lines to your speakers and not TS cables.
Sep 02, 2011 | Soundcraft FX16ii 16Channel Audio Mixer
Central air and heat unit heat turns on for 1min and then heat turns on aux. heat
All aux. heat comes on when the thermostat calls for more than 2 degrees of the ambient temperature. Once the 2 degree gap is closed, aux. heat drops out of the circuit.
Some installers wire the thermostat to activate aux. heat every time heat is called for.In this wiring configuration the aux. heat stays on.
Apr 07, 2009 | Kenmore Heating & Cooling
Cant seem to get the aux up on my kenwood kdc-237 tried from src button but to no avail can anybody advise please
Its becuase the aux is turned off as default so you have to activate it.
Put the unit into standby mode
Press menu for at least a second untill menu appears and then select the aux option and edit it to either aux on1 or aux on2 or aux off.
Anyproblems and you can download the pdf for free from internet
Mar 16, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Activate the aux
put your player on standby when this is done press the volume botton in then go down then menu and turn the aux to on job done
Mar 07, 2008 | Kenwood KDC-MP7028 CD Player
How do I activate AUX input?
Hi Greg212,
Got your procedure out of the manual. Look below. Hope this helps you.
Nov 28, 2007 | Alpine CDM-9803 CD Player
Mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Oct 31, 2007 | Kenwood Sirius KDC-MP522 CD Player
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-1730R CD Player Logo
26 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
