Question about Nokia Cell Phones
Mobile phone went along with the clothes into the washing machine
Phone was not damaged but it is not starting up i have kept in fan and dried it but it is not starting up.
please send your solution to the following email address
jaikanthjay@gmail.com
    Scholar:
  • 106 Answers
Take the phone apart and clean it with a toothbrush and some PCB cleaning solution...
Posted on May 08, 2009
Zanussi Washer Dryer wont wash!
Sounds like the switch that tells the controller that the door is closed and locked is actually bad or the plastic molded part holding the switch is broken. Inspect the interface for cracks.
Nov 22, 2014 | Zanussi Washing Machines
After the clothes have been washed and the dryer automatically starts why do my clothes go steaming hot and never dry...?
hello.. probably your drier have deffective fan.. the heater is on but there is no transfer because the fan is not working making your clothes hot but not dry..
Apr 24, 2011 | Washing Machines
I went to use it today and it wasn't working properly. i set the laundry in, put in the detergent, closed the door and then deposited my money and selected the cycle. the machine ran for 1 minute then...
yes, your guess is most likely correct. Problems on the water supply into the drum of the washing machine. you can check the start of the tap water, hoses and water inlet valve Selenoid. Hopefully help.
Aug 18, 2010 | Maytag MAH21PDD Commercial Front-Load...
Samsung F480 dropped in water
have the phone check at a repair center and have them test the camera the problem sould be from the board.
Jun 06, 2009 | Samsung SGH-F400 Cellular Phone
Dryer not drying clothes
If you remove the lid you will see the element on top of the drum.
There are a couple of thermal cutouts mounted on it which would be the first thing to check.
Also look for the obvious broken wires etc.
Also can you hear the fan running when machine is in operation?
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WD640 Front Load...
It takes a long time to dry a load of clothes
sounds as if you may have an issue with a blocked/clogged ventin, perhaps wher it leaves the home, a unit that is not able to expell the heat will tend to not dry the clothes properly, 2-3x to dry a good sign of venting issue
Jan 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washing machine that no longer can spin dry laundry
The washer has a reversable motor. One way it washes and everything is sweet. the other direction the water pumps out and the brake gets released allows the tub to slowly start spinning and eventually spin out the water from the clothes. So what can go wrong? The thrust washer will not release the tub and let it spin. A new kit comes with everything you need to replace it.Since you never said what brand you have I am oly guessing of course by the symtoms you have given.eee0328.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 15, 2008 | Washing Machines
Dryer
It sounds as if you have the dryer button pressed in before you start the wash! If you don't. it is likely it is stuck in or the switch is shorting out on the back. Unless you are a competent DIYer, find someone who is to check the electrical connections and test whether the switch is working correctly.
Sep 14, 2008 | Ariston Technologies Ariston AWD12 Front...
Mobile
Not likely, wash and tumble usually means dead phone.
You can try drying it over night with a hair-dryer or on a heater, but most likely you have to go get a new one. :-(
Oct 16, 2007 | Cell Phones
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Cell Phones Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
