Question about ViewSonic N4785p 47 in. LCD TV
Dark one side - ViewSonic N4785p 47 in. LCD TV
Why is my heated auto dimming driver side and rear view mirror getting dark when driving
Look in the fuse box for the fuse it will likely have other things on it but nothing to high voltage .
Pull the fuse and see what happens .
Honestly I have never heard of this .
Unless the mirrors lit or damaged somehow from to much heat damaging the coating on the back of the glass making it not a mirror any more .
This sounds like a factory defect
Feb 19, 2016 | 2004 Chevrolet Avalanche
LN46A530 Samsung LCD -half a screen black-stays for 30 minutes, than turn to some what normal, but not quite all.What is the problem , what is the part to replace?
is it completely dark or just very dim or dark on one side? if it's just dark on one side, you have a failing LCD panel, very common for older Samsung panels. If it is completely black on one side split down the middle, you could be dealing with a bad panel, bad t-con board, or a faulty LCD panel ribbon connection.
Sep 07, 2013 | Samsung LN46A530 46 in. LCD HDTV
LN-T4971F dark on the right side of screen.
Hey Steve,
Sorry to be the bearer of bad news but you have a bad LCD panel tab. There are videos on youtube that show you how to repair this but they are temporary in nature.
Jun 28, 2013 | Samsung Televison & Video
Picture is dark on one side
you may need to replace the backlight.
Mar 02, 2013 | Samsung LN-T4665F 46 in. LCD Television
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
We have a Mitsubishi sd200u projector.The right side of the screen is dark,there is still picture but very dark.We thought it was the bulb,ordered and replaced that,and we are still having the same...
Does the dark side have a well defined straight vertical edge or is it ragged and blurry.
Is the picture still visible in the dark area, or has the picture disppeared and there's this darkness that has taken over.
I'm thinking that the optics may have been jolted. Has the unit suffered any impact or the like.
Mar 19, 2011 | Mitsubishi SD200U Multimedia Projector
Need a wiring diagram for 696 seriess switch
You don't need a wiring diagram.
The screws tell the story.
On one side of device has 2 screws.
On other side has 2 screws.
Green screw is for bare ground wire.
1) One side will have dark screws and the other side will have brass screws. The dark screws will be connected together with a brass plate. The brass screws will be separate.
-or-
2) One side will have brass screws and the other side will have silver screws. The brass screws will be connected together with a brass plate. The silver screws will be separate.
#1 Hot from breaker connects to dark screw. Wires to Load (light,fan) connect to brass screws.
-or-
#2 Hot from breaker connects to brass screw. Wires to Load (light, fan) connect to silver screws.
Nov 08, 2010 | Pass & Seymour #696LAGCC6 15A Almond 3WY...
Side by side sub zero refrigerator: freezer is
still not clear. in your question you say refrig side is dark and not running, then you say you put a temp guage in it overnight and it's steady. So you DO have cooling in refrig? If it's just the lights, yes it could the switch or it could be the light bulbs.
Jul 16, 2010 | Sub-Zero Refrigerators
NEED TO TIME CAMSHAFTS PLEASE EXPLAIN. THANKS
Flats of all four cams on the ends opposite gears need to be parallel to top of head where cam cover bolts on. Dark links on transmission side of cam gears should line up with pins at 12:00 positions on cams. Dark links on pulley side of gears should line up with marks on intake gears. Dark link on balancer shaft gear lines up with tooth at 5:00 position. Dark link on crankshaft gear lines up at 4:00 position.
Here is a diagram of the pulley side marks.
Here is what the marks look like on the tranmission side of the gears on the front head:
Find more pix on the head gasket page of 99intrigue.shutterfly.com
Mar 09, 2010 | 2000 Oldsmobile Intrigue
FAX machine prints a dark band down one side of the paper
Your thermal head is defective. No replacement parts available.
Nov 16, 2009 | Office Equipment & Supplies
ViewSonic N4785p 47 in. LCD TV Logo
11 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
