Question about Smartboard Smart Board UF55 Projector Lamp
WHITE DOTS ON UF 55 PROJECTOR - Smartboard Smart Board UF55 Projector Lamp
My Sanyo PDG_DX100 projector only 100 hours now, its started white dots and balck dots how to fix it. if DMD chip problem, how much it cost me.
Sanyo PDG DXL100 1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200 We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
Jul 23, 2014 | Sanyo Office Equipment & Supplies
Black and white dots on screen
Hi Emmanuel,
I think your projector lamp and LCD area is dusty.
please use pressurized air can and clean the area.also check the dust filter.
do it carefully.
regards,
nuwan
Jan 27, 2014 | NEC NP215 Portable Projector
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
White dots on the screen
Need more info. But initial suspicion is there is a problem with your projector.
Are they stationary and always in the same position? You may have bad pixels.
Are the dots there with no signal going to the projector?
What is connected the the projector? Detail the video path - try all the sources. The dots still there and in the same position on all sources?
It is probably your projector.
If some of your sources are fine - the problem might be from a connected source.
Hope this helps.
Aug 26, 2012 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Hundreds Of White Dots On My Display... Looks Like Stars!
The link to the article explains the the cause of the white syndrome none of the previous internet experts have a correct solution. I have the same problem the link to the article attached is for a Mitsubishi projector but all the chips are the same. http://www.fixyourdlp.com/2012/04/26/solve-the-mitsubishi-white-dot-problem-for-under-200/
Mar 21, 2012 | Toshiba TDP-SP1 DLP Projector
Many white dots appears on the screen of my benq w600 projector
Jacob, what element on the mainboard is the source of these dots? I have the same problem - it is only one dot now, but I think there will be more with time.
Also, the second question is: how do I unscrew the mainboard from benq W600+? I remoced the metal cover, unplugged all the cables, but there's something still not letting the board go.
Jan 29, 2012 | Office Equipment & Supplies
How do you clean the dust out of the projector, there are particles that look like small white stars on the black areas and black stars on the white areas. Is this dust?
If you focus the image on a screen up close to the projector and notice small rectangular black and white spots, then you have pixel failures.
Jul 11, 2011 | Optoma TX542 Projector
The projector has several white dots on the screen. how can i fix it, it started with a few white dots then every time i used it, it doubles and doubles until it became many dots.
I have the same problem. I think we need a class action!
http://s1231.photobucket.com/upload/albums/m3231/?location=projector+spots
Oct 06, 2010 | BenQ MP511 Projector
Smartboard Smart Board UF55 Projector Lamp Logo
201 people viewed this question
Top Smartboard Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Smartboard Office Equipment and Supply Expert? Answer questions, earn points and help others
