Question about Cell Phones
Thermo-guard 810TN manual - Cell Phones
Fault 14 on rinnai energysaver 556ftr
Hi.
Error code 14 is Overheating error.
The error can be caused by the high limit sensing overheating and cutting off. In that case the thermal fuse may not blow. The high limit can be reset tripping circuit breaker and allowing the unit to cool down with power off.
If that does not work , then the thermo fuse has blown
In fact tis unit has a thermo fuse. (refer to manual).The thermal fuse can be tested reading continuity. If thermal fuse has blown, then replace the the thermo fuse. If the thermo fuse blows again, then there is a condition causing overheating. b260351.gif
Here Full service manual.
Unless you are a trained technician call Rinnai support ringing the number in the manual. Some of testing and repair operations described are not suitable for the home user.
Regards.
Ginko.
May 31, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
I need a operators manual and parts list thermos gril2go
Ok, well you didn't list a model number so here is what I can give you: the first link below takes you to the Owner's Manual for a Thermos Grill2Go Fire+Ice Model No. 465630003:
http://www.appliancefactoryparts.com/content/pdfs/8794.pdf
This second link takes you to an illustrated parts list for Thermos Grill2Go Fire+Ice Model No. 465630003:
http://www.appliancefactoryparts.com/gasgrillparts/helpcenter/breakdowns/thermos/thermos-465630003.html
Oct 26, 2009 | Thermos Grill2Go Fire+Ice
2001 kia sportage need to get info on how to change the timing belt, 2.0 motor forward facing motor, needs power steering replaced, timing belt.
Below are the steps..
Disconnect the negative battery cable. Remove the two fresh air duct mounting bolts on the radiator. Loosen the fresh air duct clamp at the intake housing. Remove the hose at the resonance chamber. Remove the frech air duct. 2bea4d1.jpg Remove the five cooling fan shroud bolts. ab00c68.jpg Remove the four thermo-modulated fan nuts. Remove the four thermo-modulated fan cooling fan shroud at the same time. 289c5ca.jpg Loosen the two generator mounting bolts(A and B). 2a96c03.jpg Loosen the generator drive belt from the generator by loosening the adjusting bolt(C). Remove the generator drive belt. Remove the fan pulley. Remove the four splash guard mounting bolts and splash guard. f912ce0.jpg Loosen the A/C idler puller nut(A). c0690b5.jpg Remove the A/C drive belt by loosening the adjusting bolt. Loosen the power steering pump lock bolt and mounting bolt. 843d3b3.jpg Remove the power steering belt. Remove five bolts and the upper timing belt cover. Refer to Timing Belt. Remove two bolts and the lower timing cover. Refer to Timing Belt. Loosen the tensioner lock bolt and pivot the tensionder pulley outward to remove the tension from the timing belt, then re-tighten the tensioner lock bolt. 7ca4ca0.jpg NOTE: Tightening Torque : 27-38ft·lbs(37-52N·m) Mark the timing belt rotation for proper reinstallation if it reused. Remove the timing belt. Be careful not to allow oil grease on the belt. c5d4c02.jpg Regards, Jeep Brainy
Sep 16, 2009 | 2001 Kia Sportage
Rear splash guards
Remove, shorten, replace. Do not just remove. Or, there is a pre-shortened (invisable) aftermarket splash guard available. It's a quite simple operation but do not attempt any modifications or repair w/o a shop manual. I've had very good luck obtaing shop manuals by typing in the search box of www.yahoo.com: Suzuki Bandit 600/1200 shop manual repair manual
Nov 10, 2008 | 2005 Suzuki GSF 1200 Bandit N
Kenmore undercounter dishwasher quiet guard
Presuming that your circuit breaker is not tripped and you have power to the dishwasher, it appears that your thermo fuse is blown. You can replace it for around $20. It comes in a kit form or you can replace the thermo fuse for around $1. The part number is NTE 8096 Thermo Fuse 98 degrees Celsius and solder it in yourself. It is located on the circuit board that contains all the relays and the main computer chip. It clips on and off.
Sep 14, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Gas bottom shelf for Thermos Grill2Go ,Fire and Ice.
try this: http://www.thermos.com/contact.aspx
Mar 07, 2008 | Thermos Grill2Go Fire+Ice
Cell Phones Logo
154 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
