Question about Dryers
Dryer turns but wont heat - Dryers
    Sergeant:
  • 175 Answers
Hi..the reason to this problem may be due to two reasons.
It may be either thermostat or the heating element.
check this out..
thank u..
kindly rate my response..
Posted on May 08, 2009
Dryer heats up wont turn belt is fine
if you can't turn shaft by hand, motor sized or bearings(on both ends of shaft) shot.
Jul 08, 2012 | Kenmore Series 70 80 90 PN281798 Dryer...
Replaced heating element and it still wont fire up
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 02, 2010 | GE DVL223EBWW Electric Dryer
It wont heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 09, 2010 | Dryers
My dryer wont heat, but air flows well. Also, it
# 1 Check to see if your timer is turning as the dryer is running. If not it will need to be replaced.
# 2 You will need to verify that your heating element is coming on when the dryer is running
Oct 02, 2009 | Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Dryer turns on but wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
uiit
Mar 14, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer will not heat but turns on and spins but no heat.
check breaker first it will run with the breaker tripped but it wont heat so turn off and on then check dryer for heat.dryers have a thermal fuse when they go bad it wont heat they are located on the element cage and are smaller than the thermostats.and if that is good then most likely element.but it usually helps to know what brand?
Mar 11, 2009 | Dryers
Heating element wont turn off.What would cause that?
the heating elkemnt may have broken and is laying against the housing forthe heatere causing the "short"
Jan 23, 2009 | Maytag HYE3658AY Electric Dryer
Amana dryer wont work
I'LL let you know after the Amana repair man comes out.
Mine is doing the same thing and I can't figure it out
Jan 14, 2009 | Amana NDG2335AW Gas Dryer
Dryers Logo
Top Dryers Experts
