Question about Zebra TLP 2844-Z Thermal Label Printer
Actual driver ZDesigner 1.5.09
Need actual driver
Where to find acer Z3100-U3072 driver
what actual device are you wanting driver for ?
device drivers are supplied by the device manufacturer .
so if you are adding a device you will usually find the driver at the manufacturers web site .
from the model number you provided you need a windows 7 64 bit driver.
if you need drivers for the actual computer devices check the acer website under links for support - downloads - drivers.
May 31, 2016 | Acer Computers & Internet
Windows 7 - adjust monitor screen??? using a 15" monitor and now have black space around picture.
Control Panel/Appearance and Personalization/Display/Adjust resolution. Try higher resolutions on the list.
If that doesn't do it I would go to Device Manager, and update driver for display adapter. May need to go to the manufacturers website
and Support Tab for drivers.
May 01, 2015 | Computers & Internet
Need motherboard drivers for my hcl Amd semphron board...I need it badly!!! Plz giv me correct website to download all my sound,vga and modem drivers
Hi, you will need to go onto the actual manufacturers website who made your computer. Then search for your computer, then the drivers you need, without knowing your actual manufacturer i cant provide you with direct links
However, if your motherboard was taken out of an old computer or brought new. try here http://support.amd.com/us/Pages/AMDSupportHub.aspx
Then download automatically detect and install
Hope this helps and please rate.
Mar 08, 2012 | Computers & Internet
Hi I am printing barcode labels on a Zebra Tlp2844-Z. I can print resident barcodes in passthrough mode using the old Zebra driver (1.0.0.43) but the barcode does not print using the ZDesigner driver...
Have you tried creating the barcode / label using the ZDesigner software? It is available free on their website and I'm sure you'll find it easy to use. Hope this helps!
Aug 23, 2011 | Zebra TLP 2844-Z Thermal Label Printer
The actual print output is different from the actual view displayed from the accounting software.
This is usually caused by a driver issue. You can try to download the newest driver for your printer from the manufacture website. I would suggest using a pcl driver.
Mar 07, 2011 | Office Equipment & Supplies
Can i upgrade windows7 in IBM t40
this is an old model. if your actual specification actually meets Win 7, it may work, however, the challenge would be with the drivers. You can go to http://www-307.ibm.com/pc/support and select your correct T40 edition to confirm the availability of the system drivers that you need after making sure your actual specification like process speed, amount of memory available, video controller and disk space are all met.
Sep 24, 2010 | IBM ThinkPad T40 2373 Notebook
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
Please help. Printer not printing. Urgently...!!!
Sounds like you chose print to file for the port in the driver instead of what it should be set for. comm for serial cables. lpt1 for parallel, usb for usb. by having it set the way you do it is told to save the code. goto printers and faxes and right click on the zdesigner print driver and chose properties. then click the ports tab and chose the correct port.
Jul 02, 2009 | Zebra S4M Thermal Label Printer
Zebra 2844
There is specific coding you need to use to get it to work. Word documents add special characters to the batch files causing them not to printer properly.
You could try a merge to printer opertion in word and see if that will work. Make sure you to turn the printer on and off before attempting it to reset the control codes.
Jul 21, 2008 | Zebra TLP 2824 Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
722 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
