Magnavox dvd vcr combo HQ MTS/SAP
Vhs side is damaged, turns on but turns off in seconds,what can be the problem. VHS side is broken due to tape getting stuck and breaking a small piece of white plastic off inside. can it be fixed by myself or does it need a doctor.
Gigatech
  • 259 Answers
SOURCE: romote code for CLO15 (philips magnavox )
Philips PH-DVD5 manual:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502143_PM_EN.pdf
Posted on Dec 17, 2007
  • 579 Answers
SOURCE: stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Posted on Jan 08, 2008
Sparky-UK
  • 129 Answers
SOURCE: Code for Magnavox DVD VHS Recorder
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC6131
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
Posted on Jan 23, 2008
SOURCE: Phillips magnavox tv/vcr combo need codes to program remote
most universal remote controls will not operate the combo type units. Contact www.remotes.com for a repoacement remote.
Posted on Nov 26, 2008
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
I hav a magnavox mwc24t5 triple combo. When I put a vhs tape in it spits it out. Sometimes it gets stuck in there and I have a time trying to get it out.
Please check your VHS tape's CONDITION. See if U can play it on another VHS. BE CAREFUL. sounds like a damaged VHS. You might need to take that to the shop. Better to have it checked than damage your materials. Had a similar situation with a DVD/VHS. Finally, the VHS got stuck inside. Thankfully the shop fixed it but my VHS never worked again properly.
Dec 20, 2014 | Televison & Video
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
Dec 31, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Copying VHS tape to DVD
Hi.
I'm sorry, but according to zenith xbv323 VCR/DVD combo user's manual page 24 you can ONLY copy DVD to VCR and not the other way
Feb 26, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr wont work
Reset the VCR by unplugging/replugging, and then run a vhs cleaner.
May 20, 2008 | Philips Magnavox 20MC4304 20 in....
I cannot watch my dvd's i taped on the philips on any other dvd player
YOU MUST FINALIZE THEM BEFORE YOU PLAY IN OTHER DECKS, CHECK YOUR MANUAL
ON FINALIZING THE DISK
Dec 17, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
