Question about MSI K8MM-V Motherboard
Computer does not work first.
Motherboard is MSI K8MM-V (VIA K8M800-CE + VT8237R Chipset)
RAM is 128 DDR(333Mhz) HDD 250 GB SATA CPU AMD SAMPRON64 2600+
    Problem Solver:
  • 9 Answers
Does it power up if it does do you hear a beep on post screen, Please Briefly explain what is happening my email : colin.gila@wits.ac.az
Posted on May 08, 2009
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    I have MSI via k8m800 vt8237r chipset based board and amd athlon x2 dual core 4600 cpu ccan i suppor 1tb sata hard disk
    some of the motherboard select the kind of devices that will work for them, try to test your sata hard disk with another system if it work then try to change the board. or get another system that will support your sata. thanks
    Jun 12, 2010 | MSI K8MM-V Motherboard
    Hola tengo un drama la placa madre estaba con un disco duro zata y lo quiero cambiar por un ide pero no me deja botear como lo programo hay alguna manera de poder hacerlo placa madre:amd sempron msi k8mm3...
    Placa base MSI K8MM3-V (MS-7181) de VIA K8M800 int. DDR AGP8x VGA SATA RAID LAN ATX granel sc754
    Ampliar Ver producto en alta resolución K8MM3 MSI-V (MS-7181) int K8M800 VIA. DDR AGP8x VGA SATA RAID LAN ATX sc754 granel.
    Producto terminado. Por favor, seleccione los artículos similares en la misma categoría
    Ver más productos de MSI.
    Código: AA827c
    Marca: MSI
    N º de producto: 601-7181-020
    Enlaces: El sitio del fabricante
    Enviar a un amigo
    Imprimir
    Perro guardián
    Añadir a Favoritos
    Servicio de Ayuda
    Refiera a un amigo
    Placa base, placa base, placa madre, placa base, placa madre MSI
    Le recomendamos que adquiera junto con las mercancías
    Cable de datos al disco duro Ultra cable de datos al disco duro Ultra ATA/66/100/133 ATA/66/100/133 ... 32, -
    HUB de alimentación de 1 x 5,25 de energía HUB de 1x 5,25 "... 42, -
    Poder adaptadores de alimentación para SATA para la Reducción de disco SATA ... 34, -
    Contribuir a la discusión sólo se permite a los clientes
    que ya han comprado a nosotros.
    Las respuestas a las preguntas más frecuentes aquí.
    Descripción de la mercancía K8MM3 MSI-V (MS-7181) int K8M800 VIA. DDR AGP8x VGA SATA RAID LAN ATX granel sc754
    Calidad Placa base Micro ATX formato a un precio razonable basada en el chipset K8M800 de VIA, que pueda ser equipado con lo último Athlon de 64 bits y los procesadores Sempron con socket 754a Placa base tiene dos ranuras de memoria capaz de transportar hasta 2 GB de RAM DDR tipo 400 / 333 / 266 184-pines. Por supuesto que hay dos canales con interfaz Ultra ATA 133 y dos puertos Serial ATA, un total de hasta seis dispositivos simultáneamente. S3 Graphics UniChrome integrada de gráficos con 8 a 64 MB de memoria compartida proporciona suficiente energía para aplicaciones de oficina y el hogar. Otra extensión permite una ranura AGP 8x para una tarjeta gráfica y tres PCI versión 2.3. Disco también contiene una integrada 10 / 100 Mbps tarjeta de red Ethernet, una de seis canales AC'97 tarjeta de audio, un paralelo y un puerto serie, ocho puertos USB.
    Parámetros y especificaciones:
    Procesador:
    Socket 754 Athlon 64 / Sempron
    Chipset:
    De VIA K8M800
    VT8237R
    Memoria:
    2 tomas de corriente de hasta 2 GB DDR
    Apoyo a 266/333/400 MHz
    Las ranuras de expansión:
    1 x AGP 8x
    3 x PCI
    Controlador de disco:
    2 x Ultra ATA 133 (máximo 4 dispositivos)
    2 x Serial ATA 150 (hasta 2 dispositivos)
    Tarjeta de vídeo:
    S3 Graphics UniChrome 8 a 64 MB de memoria compartida
    Tarjeta de sonido:
    Seis canales de VIA VT1617A, 5,1
    Cumple con las especificaciones AC97 v2.3
    Tarjeta de red:
    VíA VT6103L 10/100 PHY
    Entradas y salidas:
    1 x puerto paralelo
    1 x Puerto serie
    1 x VGA
    PS 2 x / 2
    1 x audio I / O (Line-in/Line-out/MIC)
    4 x USB 2.0
    1 x RJ-45
    conectores de expansión:
    4 x USB 2.0
    1 x Puerto serie
    1 x S / PDIF-outNapájení:
    1 x 20-pines ATX
    1 x 4-pin ATX 12V
    Dimensiones:
    244 x 215 mm Micro ATX
    Mar 05, 2010 | MSI K8MM3-V Motherboard
    Installed new processor and computer doesnt turn on just flashes green steadily?
    CPU • Supports 64-bit AMD® Athlon™ 64 processor (Socket 754) • Supports 2800+, 3000+, 3200+, 3400+, 3700+ • Supports Sempron 2600+, 2800+, 3000+, 3100+, 3300+ Chipset • VIA® K8M800-CE Chipset - HyperTransport connection to AMD Next Generation of CPU - 8 or 16 bit control/ address. data transfer both directions - 800/600/400/200MHz "Double Data Rate" operation both direction - AGP v3.0 compliant with 8X transfer mode - On-board Graphic shared up to 64MB • VIA® VT8237R Chipset - Ultra DMA 66/100/133 master mode EIDE controller - Integrated dual channel native Serial ATA/RAID controller that will supply 150MB/s and support RAID 0, RAID 1 - ACPI & PC2001 compliant enhanced power management - Supports 8 USB2.0 ports. (Rear x4/ Front x4) Main Memory • Supports two 184-pin DDR SDRAMs up to 2GB memory size • Supports DDR400*/DDR333/DDR266 DDR SDRAM (*Refer to MSI recommended modules) • Note: PC3200 (DDR400) maximum 4 banks (2 double-sided) only
    I can't seem to find any usefull information as to why there may be a LED flashing on the motherboard. Re-check the memory speed, and configuration, as well as the CPU that it is supported. This seems to be a fairly new motherboard, it may still be under warranty, contact MSI and request an RMA if you feel the motherboard is faulty.
    May 31, 2009 | MSI K8MM-V Motherboard
    M/b cannot recognize SATA HDD
    This is common to other mainboards, the SATA controller have it's own BIOS, but it only works correctly using two identical SATA HD's at same time for data protection purposes. If you have a free PCI slot there are expansion cards based on VIA chipset VT6421 with 2 internal SATA ports, other external and one IDE. See one here
    May 11, 2009 | MSI K8MM-V Motherboard
    Problem with audio driver
    haii,
    Im using ms 7173 ver 1 motherboard and via chipset VT8237R and AMD sempronprocessor. I have problm with my audio driver so pls help me for downloading the corresponding driver.
    Thanks
    Sajeesh
    Jul 08, 2008 | MSI K8MM-V Motherboard
    Pls help for downloadin via vt8237r audio driver for msi 7142 motherboar and amd processor
    pls help me to download vt8237 plus audio driver / that msi m/b driver...pls urgent...
    Jul 07, 2008 | MSI K8MM-V Motherboard
    Exact chipset
    You can download the drivers at
    http://www.msicomputer.com/product/p_spec.asp?model=K8MM-V
    Mar 04, 2008 | MSI K8MM-V Motherboard
    MSI K8MM-V Motherboard Logo
    181 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    Alun Cox
    David
    David
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
