Question about Canon Office Equipment & Supplies
Canon ir jam codes 020A - Canon Office Equipment & Supplies
4 Suggested Answers
SOURCE: We have a Canon IR-7105
it is a transfer corona problem ,clean it first.even its not ok change the corona wires.
if its not ok finally change the transfer corona .
Posted on Jan 21, 2009
hamzaskilltd
  • 316 Answers
SOURCE: paper jam error 020A
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} toner clogging between sub hopper and developing assembly
Posted on Aug 15, 2010
  • 62 Answers
SOURCE: jam code 0211 in canon
Clean or replace roller after fusing unit.(heater) Slide out middle section>Lift green handle on left to expose rollers.
Posted on Sep 03, 2010
HOw To Remove Canon IR 3300 Error Code 000010-0000
Its main motor problem.But you check fixing unit bush or fixing unit very hard. Also check Drum unit . If it is tight and jammed than service it. Any other assembly moving jam than service it.
Sep 19, 2017 | Canon Office Equipment & Supplies
How to clear e000067 for canon irc2880i copier
Are you looking for Canon printer support number to sort out issue related with your printing machine? We also provide the Canon Printer customer Support, Canon Pixma Support Number, software installation, software upgrade, cartridge jam, paper jam issues and much more. Canon Pixma Printer Support
Jan 18, 2016 | Canon Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Canon ir c2550 error code e000025-0001
Dear
The error code indicates the toner is not supplying for (Y). The hopper motor is locked. The probable cause the sensor is not detect within 5sec. when motor is on at hopper assy. Check. the sensor,clean-replace,check the jam of motor gears,check the harness up to DC con board, check the DC con board.
Thanks.
Jan 14, 2015 | Canon Office Equipment & Supplies
Code jam 0207 in canon ir 4570
jam 0207: this jam code means paper is jamming in the fixing unit, check that unit for possible obstruction in paper path, or replace fixing film assembly
Apr 28, 2014 | Canon Office Equipment & Supplies
Jam code 205 in canon Ir 4570
Try to open up the copier where usually the paper goes through and check for any remains of bits of paper.
PS: on the screen shows which side of the printer has to be opened.
Feb 24, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
I am using Canon IR 3530 the error code is E000024-0001 please help
I had the same problem on a IR-2230 and I had to replace the Developer Assembly. Check the connection first - have you recently had this worked on?
Mar 07, 2011 | Canon imageRUNNER 2000 Copier
My canon iR 2022 is displacing the world System Error E007. If you put a paper, it also jams. What to do please ?
Canon fuser technology is hp laser printer system.This copier has a fuser film or eleventh cover.Some times its torn or short then this machine say E007.Its an error code.When occurred this E007 you should defective film.
Feb 14, 2011 | Canon iR 2022 Printer
Canon IRC3200 jams whit code OD91
Just a note to everyone, if you have not seen it you will. False jams right above the fuser (OD91). If you remove the jam the paper feeds to the same area and "jams" again. Reset the power and you are set to go. I have seen this problem on Ir C3200s and IrC3220.
Jun 14, 2010 | Canon imageRUNNER C3200 Copier
Paper jam error 020A in canon ir7200
Jan 05, 2010 | Canon imageRUNNER 1023iF Black and White...
79 people viewed this question
old marine
old marine
